E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Can a 2/08 built car have a v81 dme?
Reply
      04-19-2008, 06:47 PM   #1
mistermojorizin
mistermojorizin's Avatar
40
Drives: 135i
does anyone that has
(i) 2/08 production on the label on the drivers door
(ii) have a v81 dme label? thanks
      04-19-2008, 06:53 PM   #2
ArmyBimmerDude
ArmyBimmerDude's Avatar
Drives: Lola
Why? Do you? Is your car a 02/08 model?
2007 E92 Montego Blue 335i
      04-19-2008, 08:46 PM   #3
Dinamael
Dinamael's Avatar
Drives: 2008 BMW 335i - Dinan Stage 3
My E92 has an 02/08 build date, and was flashed with Dinan software without issues on Friday, so it didn't have the newer DME.
Is that why you're asking?
PS Holy cow, what a transformation. The power is incredible.
2008 Black Sapphire 335i Coupe 6MT
Dinan Stage 3
      04-20-2008, 02:37 AM   #4
mistermojorizin
40
Drives: 135i
i have a 2/08 135 and i hear its a bit of a pain to get to the ecu to check what version it has. so i was curious if anion with a 2/08 n54 got a v81. i know there are a lot of people with 2/08 that have v80, but this doesn't logically prove that all 2/08 cars have v80. if there is someone with a 2/08 that has a v81 this would prove that not all 2/08's have v80s
      04-20-2008, 01:54 PM   #5
Tuned335i
Drives: E92 335i
I wouldn't say it's a pain. If you've removed the bulkhead tray before, accessing the ECU to check the date would probably take 5 minutes. If you haven't done it before, maybe 15min if you really take your time. Either way it's not a big deal.\
      04-28-2008, 05:48 PM   #6
mistermojorizin
40
Drives: 135i
^I haven't done it before. And its a 135. Is it the same procedure to get to the ECU? I thought it was harder. For example, I know you can't install the sstt without removing the intake on a 135 or getting to it from under the car.
Can anyone answer my original question? Anyone with 2/08 on the driver's door with v81 on the ecu? thanks
Reply
e90post
