02-22-2017, 07:15 PM | #1 |
Rep 171
F series N55 big turbo kit
Hey guys got rid of my m235i cause I am buying a house. I have a big turbo kit from enzo racing that needs a good home. This kit needs somebody who wants to build his motor and push his car into the 10s. If we can get slightly better fueling on the platform the car will be putting down 700+ hp easy. You will need port injection, jb4 and an intake unless you want to slap a filter on the turbo. The tune can run mafless but I feel running the maf is a better way to go. You will also need to contact Enzo for the tune. I will also include a bad ass custom intercooler he made for me but you will have to do some slight modification to the fan. Nothing major we can discuss. I have all the custom coolant and oil lines. Some side notes: The exhaust manifold will not fit an awd car. My car is rwd 6 speed trans so you are good if that's your setup. rwd auto I am not 100% on but I think we should be ok. On the very first tune revision the car put down 632whp and 525wtq at 24psi and the tune got a lot better(fixed issue with the throttle body closing that was present in that original dyno) with some updates but never got back to the dyno. I would not recommend running this turbo above 22psi on a stock motor. With e85, 27 psi is the limit with the fueling options we have but this turbo could run 35psi no problem that's why I say 700+ whp is totally in reach with better fueling. EDIT: I just realized that we never tested with the stage 3 fuel it lpfp Might want to give that a shot Contents: Custom intercooler gt3586r tial wastegate and bov custom down**** exhaust mani turbo outlet to intercooler and intercooler to TB solenoid to replace DV and control bov manual boost controller with hoses needed Lets start at 4k. Shipping this will be dough so we can discuss that as well [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG]http://[/IMG] [IMG][/IMG] [IMG][/IMG] Last edited by boost82; 03-16-2017 at 07:24 AM.. |
02-25-2017, 10:02 PM | #2 |
Rep 1,422
Hey, I just got PS2 last year - been awesome. But once that turbo runs out, I'd like to go with something like this. Dammit, it's all about timing. Mind if I PM you about your experience with it? Thanks!
02-26-2017, 12:03 PM | #3 |
Rep 171
05-19-2017, 10:21 AM | #7 |
IG @bmwF9xG80
3817
Rep 7,595
Drives: G80 M3, X4M, G07 X7m50
bump for a good deal!
Tagging some RWD/6MT for you DKM3Power F30_SixSpeed R32DBP HotTea69
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
