Liqui Moly 5w-40 in Modified N54
02-25-2017, 11:00 AM | #1 |
Rep 1,070
Hey guys,
My car has almost 96k miles, 25k of which are tuned at 18PSI. I'm about to change my oil, which had been dealer 5w-30 and/or Total 5w-30 depending on whether it was "free" at the dealer or done by my local indy. I'm planning to send the current fill to Blackstone for UOA to see how the engine has done with Total at about 5,000 mile OCI, and was looking for something as an upgrade - which I'll also test. Has anyone been using Liqui Moly Leichtlauf High SAE 5W-40 in their tuned N54 and, if so, have you seen any improvements over other oils in terms of UOA, engine temp in summer, mileage, smooth idle, etc...? From what I've read, this looks like a nice choice for Chicago summers and is "reasonably" price LL-01. Thanks for your comments.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
02-25-2017, 11:39 AM | #2 | |
Rep 1,643
2007 E92 335i MT
02-25-2017, 11:48 AM | #3 | ||
Rep 1,070
JWebb335xi
02-25-2017, 12:51 PM | #4 | |
Rep 2,020
335i e92 TPC 19Ts
02-25-2017, 02:12 PM | #5 |
Rep 1,070
Thanks for the comment. The LM 5w-40 shows 82mm²/s (ASTM D 7042-04) at 40C..... So, I don't think that'll work in winter. I'll check their 5-30...
JWebb335xi
Sgop335649.50 |
02-25-2017, 02:44 PM | #6 | |||
Rep 1,643
2007 E92 335i MT
02-25-2017, 06:07 PM | #7 | |
Rep 2,825
It makes sense to switch to 5w40 if you park outside in cold weather and/or do lots of short trips which doesnt bring oil up to temp. otherwise, you'll be fine running 5w40. whether you guys are FBO or stock, and just looking for a good oil, you cant go wrong with 5w40 Motul or Liqui moly. another excellent choice is Shell rotella t6 5w40, which I recently switched to with very good results. I also recommend, and stick by 5000 mile changes like OP. Another thing worth mentioning, especially for FBO OP here, you may want to consider removing your plastic engine cover in warmer weather. It helped bring down temps by almost 50F for me. I keep it off in any temperature above 37F (outside) |
02-25-2017, 10:31 PM | #8 | ||
Rep 1,070
JWebb335xi
02-25-2017, 10:45 PM | #9 |
Rep 2,825
The main reason why modern BMW's switch to an electric water pump is for emissions and fuel economy. High temps = a more efficient burn and therefore better efficiency. But honestly 120c (250f) is a ridiculously high temperature. That means coolant temps are more or less similar and 120c (well past boiling) is the maximum operating threshold for coolant where it will work well. I remember I had an Audi with an oil temp gauge that would never go past 100c (210f) after literally shitting on it with back to back redlines on a hot summer day.. now you guys know it doesn't take much with these BMW's to see temps easily past that. Even when it's like 40f ambient temps it still makes sense to have the plastic cover removed especially when running it hard or sitting in traffic. just something I thought I'd share with you guys.
02-26-2017, 03:58 PM | #10 |
Rep 4
I use rotella T6 and I'm also just posting so I can gain privileges
03-10-2017, 05:17 PM | #13 | |
Rep 649
Also 252 is not ridiculously high for an engine at idle with the AC on on a hot summer day, it's actually pretty standard among modern cars.
17 M3 Comp
08-22-2018, 02:04 AM | #14 |
Rep 4
Hello not sure if this is completely dead but was wondering if I should use Rotella T6 on my currently mostly stock N54 w 51k miles or go with OEM Bmw oil or lastly Liqui Molly??
08-22-2018, 12:34 PM | #16 |
Rep 4
So any recommendations or like any of them will be good?
08-22-2018, 02:06 PM | #17 |
Rep 6,317
08-22-2018, 07:07 PM | #18 |
Rep 331
I just switched to 5w-40 Liqui Moly from 0w-40. I did notice that it takes a little longer to warm up but the payoff is that the oil temp is lower after running the car hard. I did throw in a bottle of liqui moly ceratec so that might also affect the temps but yeah 5w-40 is good stuff especially cause my engine runs a little hot after drives
08-22-2018, 08:43 PM | #20 | |
Rep 164
Seems to keep the varnish buildup at bay as well, my two cents. Oil really wont do too much along the lines of keeping oil temps down. After my 3rd LM oil change, I loaded mhd, checked off sport mode cooling, installed ftp low temp oil cooler thermostat and a vrsf 7" hd IC. Maintain the cooling system well and you will rarely exceed 220 oil temp. , more importantly the oil temp recovers super fast even after stop n go traffic with the ac on. Stock thermo opens at 230, ftp targets 220. GL. This is based on NJ summer observations, so similar to Chicago. Last edited by Cabdriver; 08-22-2018 at 09:01 PM.. |
zero2sixtyZ954.00 |
08-23-2018, 06:36 PM | #21 |
Rep 2,020
Yes that oil and grade is fine too
335i e92 TPC 19Ts
08-23-2018, 07:31 PM | #22 |
Rep 9,209
