Oil cooler recon.
04-20-2008, 10:57 PM | #1 |
Rep 4,726
Oil cooler recon.
Took the lines off to get fitting sizes and stuff today. The stock cooler fittings just push in, are held with a bolt, and seal with an O ring. If you look though you will see the same passageway is shared by the bolts on the top of the housing. So one could actually use the top to put fittings on for a new oil cooler. The question is though, which oil cooler will the oil flow to if you did this. Obviously it will take the path of least resistance, but I doubt all the oil would flow through one and not the other. It may not be too unbalanced at all. Especially with an after market oil cooler that's probably less of a restriction then stock, if anything it would flow more through it. I may try this before trying to hunt down the stock line fittings.
04-21-2008, 02:15 AM | #3 |
اوليسيس
198
Rep 4,678
^^^^^^^^now you show up.
04-21-2008, 12:21 PM | #5 |
Rep 4,726
Lol, and it actually wasn't that hard to pull these off, why didn't you try that first?
04-22-2008, 01:17 AM | #7 |
اوليسيس
198
Rep 4,678
oh.....i guess i'm slow. you wanted to add an additional cooler? i thought you were going to spray it with the washer fluid?
04-22-2008, 01:22 AM | #8 |
Rep 4,726
That was only a temporary thing since I won't have one in place before my next track day in the summer heat, which I'm still going to try (along with removing the cowl).
04-22-2008, 01:26 AM | #9 |
اوليسيس
198
Rep 4,678
where would you put the second one? you are already occupying the both lower vents.
04-22-2008, 01:34 AM | #10 | |
Rep 4,726
Last one would be best, but the mounting would be difficult, longer lines would have to be run and a little ground clearance would be lost (collapsible scoop would fix and be easy to make).
04-22-2008, 08:19 AM | #11 |
Rep 325
something like this behind the kindeys. Its 24" wide
I had to fight all my life to survive. They were all against me... but I beat the bastards and left them in the ditch. Ty Cobb
04-22-2008, 08:36 AM | #12 |
Modder Raider
759
Rep 8,633
Drives: M3
O-cha,
This is great stuff! Please let us know more about what you find, because I'm going to Laguna Seca in June and I'd love to go through those turns with cooler oil. **EDIT** You're definitely looking at adding and not replacing, correct?
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
04-22-2008, 08:46 AM | #13 | |
Modder Raider
759
Rep 8,633
Drives: M3
What do you mean by the same housing and fittings? It looks like it's somewhat of a compression fit since the pipes are going through the top fitting.
04-22-2008, 11:21 AM | #14 | ||
Rep 4,726
The question I wanted to discuss was where the oil would flow. Since the oil cooler would not be in series (from thermostat to oil cooler, out to second oil cooler, out back to thermo stat) but in parallel instead (two oil cooler lines connected to the same feed port, oil can travel to either cooler and return to the return port) if the oil would flow through both oil coolers in this configuration or not. It should follow the pass of least resistance. The question is will the resistance equalize enough to provide balanced flow to both. Do I need to use paint?
04-22-2008, 11:48 AM | #15 |
Rep 201
Essentially isn't it the same as WalkedU's set up since he put in a T in his oil line to supply the second cooler?
As long as the oil pressure is good, I don't think you'll see a problem running oil coolers in parallel. |
04-22-2008, 11:52 AM | #16 |
Rep 4,726
Well I know pressure doesn't directly relate to flow, and didn't he have not the best results with his? I'm not sure as he wouldn't tell me a dam thing about it.
04-22-2008, 12:10 PM | #17 |
Rep 201
Understood that pressure doesn't equal to flow, however if your oil capacity is greater with the second cooler, I doubt that the stock cooler will have enough flow to satisfy the greater capacity so it would have to flow to the second cooler. As you said, path of least resistance. In that case it would be the second cooler as long as pressure was maintained.
Yeah WalkedU didn't respond to my questions either about the setrab. Although it sounded like his set up was pretty sound. I've seen other cars run with parallel coolers without issues. |
