Cannot communicate to ECU when I plug in iDrive unit?
02-27-2017, 10:29 PM | #1 |
Rep 346
Cannot communicate to ECU when I plug in iDrive unit for some reason with Ista or using MHD to pull codes won't work I keep getting "no communication with ECU" and when I completely disconnect the iDrive unit it DOES allow me to connect and read codes. Also on the back of the iDrive unit for some reason I'm missing an orange cable that connects to that orange connector? Any ideas?
Here are the codes when the iDrive unit is out. I'm having another electrical issue as well. Any input on those other codes? Just to note, the iDrive unit works fine when I plug it back in I get sound the screen/navigation works and all. Last edited by f82_spooly; 02-27-2017 at 11:22 PM.. |
02-27-2017, 11:26 PM | #2 | |
Rep 346
He said it was interfering with that and the CAS or something like that so he pulled that module out and when he reconnected the headunit it wasn't working anymore. so he left it unplugged. It came back to me I plugged it in and tried to read codes and no communication. I disconnected the iDrive and then i was able to pull codes. |
02-27-2017, 11:37 PM | #3 | |
Rep 346
I'm not sure what you mean. But when I plug in all the cables in the back of the CIC. No communication with ECU/cannot read codes. When I disconnect all those cables from CIC unit I can connect to ECU and read codes. The CIC unit IS working because I do get sound and the video comes up on the screen and all. But I did read that the CIC unit has a couple of modules inside it or something and that there is a supposed to be a red fiber optic signal correct? |
02-27-2017, 11:42 PM | #4 | |
Rep 346
Yes the JB4 is turned off. I was planning on even taking it out completely in the next couple of days since it might be the cause of my issue? Not sure. |
11-06-2019, 04:09 PM | #5 | |
Rep 36
The only code showing on my car for now E1E0 . My FRM was replaced by the dealer and reprogramming. Any help ? |
