BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions G30 & G31 M Performance Parts Installation Instructions DIY
      03-06-2017, 04:22 PM   #1
ajfoggy
ajfoggy's Avatar
England
1517
Drives: C63s - S205 - Brilliant Blue
BIMMERPOST
     Featured on BIMMERPOST.com
German version attached.
English versions in second post (by E90Fleet).
einbauanleitungen-m-performance-parts-g30-31.pdf
clee1982797.50
      03-06-2017, 04:44 PM   #2
E90Fleet
South Africa
1312
English versions.
Aero pieces and brakes (PDF).
G30 Aero Bits.pdf
G30 M Performance Brakes.pdf
BMW if you are reading, I need a job, Please.
ajfoggy1517.00
clee1982797.50
      03-06-2017, 04:46 PM   #3
ajfoggy
ajfoggy's Avatar
England
1517
Originally Posted by E90Fleet View Post
English
I hoping you have added what i think you have. Can't see on the app!
If so cheers!
      03-12-2017, 04:08 PM   #4
ajfoggy
ajfoggy's Avatar
England
1517
English
E90Fleet
I don't suppose you could find the G30 M performance exhaust installation?
I have looked and not found it.
I'm trying to work out if there are two different bumper trims depending upon which exhaust to have standard or M performance.
I don't want to have one fitted now for the standard and then find out I have to fit a different one for the m performance exhaust in a few weeks.
This picture from the other instructions you posted seems to indicate a 6 cylinder look and 8 cylinder look???
      03-12-2017, 04:20 PM   #5
Jdubya
Drives: 2014 550i
M performance exhaust fits with the stock M Sport diffuser. I just picked up my car with the M performance exhaust. Tips are nice but the exhaust is pretty loud and drones quite a bit under light throttle.
ajfoggy1517.00
      03-12-2017, 04:26 PM   #6
ajfoggy
ajfoggy's Avatar
England
1517
Hmm, odd I wonder what those two part numbers are.
The problem is the the parts/dealerships don't know these cars or parts that well yet.
The exhaust is not available here for a few weeks.
      03-12-2017, 04:48 PM   #7
E90Fleet
South Africa
1312
Sorry, that one was not out yet last I had access.
Will look next time again
The kit ending "409" in your last post is for all except M550 while the "410" one is for the M550
I went and triple checked the parts system.
If one looks at the M Performance exhaust tips on the parts system it says you need the 8 Cylinder cover from the M550
So looks like you need the "410" kit if you will be fitting the M Performance exhaust and its tips
      03-12-2017, 04:50 PM   #8
E90Fleet
South Africa
1312
Diffuser or cover (silver part on M Sport bumper with holes for exhaust)?
The tips say they need the M550 cover, but the 2 diffusers are common between all the models
      03-12-2017, 05:00 PM   #9
ajfoggy
ajfoggy's Avatar
England
1517
Thanks for that.
So to sum things up.
Any model without M performance Exhaust = 409.
Any model WITH M Performance Exhaust & 550i = 410.
But you definitely need one wither 409/410 to fit the carbon diffuser. Talk about making things complicated by having a two piece diffuser with 3 different parts....
      03-12-2017, 05:05 PM   #10
remmib
remmib's Avatar
Norway
1571
Drives: 2013 F10 520d M-Sport
This is what I said in this thread when we discussed this.
http://g30.bimmerpost.com/forums/sho....php?t=1357408
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      03-12-2017, 05:21 PM   #11
E90Fleet
South Africa
1312
Yes, the diffuser is the same (as per the linked thread), but the cover is different for the M Performance Exhaust
Interestingly the parts system doesnt yet have a warning on the page where you see the cover.. You only find it when looking at the exhaust tips.
They will probably update it at some stage
      03-12-2017, 05:24 PM   #12
E90Fleet
South Africa
1312
Originally Posted by ajfoggy View Post
Thanks for that.
Not quite, since only the 540i Performance exhaust is currently out on the system
So its
540i wthout M performance Exhaust = 409.
540i WITH M Performance Exhaust or M550i = 410.
ajfoggy1517.00
      03-12-2017, 05:27 PM   #13
ajfoggy
ajfoggy's Avatar
England
1517
Yep that is the thread that started me looking at it in more detail.
The problem is I have ordered carbon spoiler, carbon mirror caps, black grilles, sills and carbon diffuser.
But this bumper part has never been mentioned, does it come with the diffuser and you have to specify which one you need?
Or does the carbon diffuser fit onto the standard m sport as well??
What I don't want to happen is they fit the carbon diffuser with the standard exhaust bumper part l, then the exhaust turns up in a couple of weeks and they find they need the other bumper part. But that seems the case, I'm not going to pay for two though.
      03-12-2017, 05:30 PM   #14
ajfoggy
ajfoggy's Avatar
England
1517
Oh and the other thing is the marketing info mentions carbon tips but these don't seem to be an option at the moment, looking at the diagrams they could be switched at a later date though at they just bolt on?
      03-12-2017, 05:43 PM   #15
Jdubya
Drives: 2014 550i
//m535i15.00
      03-12-2017, 05:48 PM   #16
E90Fleet
South Africa
1312
Again, are you talking about the diffuser (No10) or the cover (No8) ?
      03-12-2017, 06:04 PM   #17
remmib
remmib's Avatar
Norway
1571
No, it sure doesn't look like that. You'll need the matt black bumper cover to fit one of the two different diffusers, in your case the CF.
      03-12-2017, 06:08 PM   #18
remmib
remmib's Avatar
Norway
1571
Looking at your pic, it looks like you changed to the M550i diffuser.
http://g30.bimmerpost.com/forums/sho...6#post21402566
      03-12-2017, 06:09 PM   #19
E90Fleet
South Africa
1312
Yup, thats what the parts system says
If you look at the parts system picture you can see the matt cover has the cutout and mounting points for the diffusers
      03-12-2017, 09:21 PM   #20
Jdubya
Drives: 2014 550i
No they said it was the stock one. Who knows!
      03-12-2017, 09:22 PM   #21
Jdubya
Drives: 2014 550i
Yeah I don't have the lower part, just the primary diffuser. It does look different when you want to go with the lower carbon part. Which looks really nice in the picture.
      03-13-2017, 01:49 AM   #22
ajfoggy
ajfoggy's Avatar
England
1517
Can we see some pics of yours please
5post
