03-10-2017, 02:32 AM | #2 |
Rep 716
Drives: F90 M5
Try it and let everyone here know
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
WolfGTI716.00 |
03-14-2017, 01:55 PM | #3 |
Rep 245
03-14-2017, 02:38 PM | #4 |
Rep 303
03-14-2017, 06:05 PM | #6 |
Rep 442
I thought doing so causes a silent code on the car that the dealer will read next time you bring it in? The flap on my M235i exhaust has started rattling and has been replaced by the dealer two times already. Wish I could just remove the stupid flap altogether.
03-17-2017, 09:58 AM | #7 |
Rep 350
03-19-2017, 11:32 PM | #8 |
Rep 245
03-19-2017, 11:33 PM | #9 | |
Rep 245
You could delete the valve BTW. I'll be getting new tips welded and planning on having them remove the valve all together. |
03-20-2017, 07:21 PM | #10 |
Rep 19
From my understanding and after testing, the vehicle will open up this valve once the vehicle is warm. That being said, I have heard all kinds of different rumors.
04-29-2017, 10:22 PM | #12 |
Rep 178
04-30-2017, 07:41 AM | #13 |
Rep 442
I suspect its actually emissions related. It snaps closed immediately on a cold start of the engine. To increase back pressure maybe? It opens approximately 2 minutes later, so there must be a reason why.
02-17-2021, 04:07 PM | #15 |
Rep 516
02-19-2021, 06:45 AM | #16 |
Rep 142
Drives: 2021 BMW M440i XD
Garage List 1984 Mazda RX7 GSL [0.00]
1999 Subaru Sambar [0.00] 1970 VW Beetle [0.00] 2024 BMW Z4 [5.00] 2021 BMW M440i Coupe [0.00] |
What I did was use BimmerLink and coded it Open. When you first start the car, the valve remains close until the engine is slightly warmer and the valve will stay open after. I like it.
03-14-2021, 02:05 PM | #17 |
Rep 537
I guess I will try Bimmerlink and code it open. Mine never has opened that I can tell. Checked after the car was full temp - it was closed at idle, went into Sport mode - it was closed at idle. Tried Sport + - it was closed at idle.
04-26-2021, 09:10 AM | #18 |
Rep 142
I just checked yesterday, apparently Bimmercode won't leave the exhaust valve open permanently. You have to use Bimmercode to open the valve, and physically unplug the connection at the valve. That's what I did yesterday, so far no CEL.
04-26-2021, 09:36 AM | #19 |
Rep 294
Drives: 2019 M240i Coupe RWD
04-26-2021, 09:40 AM | #20 | |
Rep 693
Drives: 2015 f80 M3
josh |
05-03-2021, 07:41 PM | #21 |
Rep 7
I had pulled the clip connecting the flap shaft to the servo and wired the flap open. It still wasn't loud enough so I replaced the muffler with the M Performance exhaust. No flap, plenty loud and could care less what the neighbors think ;-)
MassNerd171.00 |
05-10-2021, 01:24 PM | #22 |
Rep 126
Drives: 2024 BMW 228i Gran Coupe
Just installed the M Performance Exhaust on my M 240i. I used the instructions for the Dinan installation to move the valve actuator to another location and left it connected. It still, technically, operates so no opportunity for any codes or faults. I did this exact same thing when I put a Dinan on my 2018 330i. I ran it this way for two years with 0 issues.
