03-10-2017, 07:26 PM | #1 |
Meh
928
Rep 781
Drives: M3CS & Cayman S
BBS FI R Question
3/4 of my wheels came in (boo to the missing wheel). i also got a hardware package for centering rings.
the center bore on the wheels are marked 72.5mm, which is what i would expect. i'm wondering why i got an extra hardware kit that has the same center bore? should i not use the hardware kit? |
03-11-2017, 08:55 AM | #2 |
Rep 368
I'm sorry I'm not really able to answer your question properly and will now ask you another question.
Are you putting these wheels on a M2 and if so, what size tires are you using? |
03-11-2017, 02:22 PM | #4 | |
Meh
928
Rep 781
03-11-2017, 04:45 PM | #6 |
Meh
928
Rep 781
03-11-2017, 05:49 PM | #7 | |
Rep 2,384
I did a lot of digging on their setup a few weeks back lol. |
03-11-2017, 07:44 PM | #8 | ||
Rep 368
03-11-2017, 07:46 PM | #9 |
Rep 368
I'm looking to get myself a set but unsure what to do. I kind of don't want to drop that much money and have to stretch out the stock tires. Hopefully if you're lowered on BMW's M performance coilovers at the recommended setting we could go with a 255/275 setup and have no issues.
03-11-2017, 07:58 PM | #10 |
Meh
928
Rep 781
i'm on kw v3 and not slammed all the way. pretty sure i will be okay when its time to replace tires and go wider.
03-11-2017, 08:00 PM | #11 |
Rep 368
03-17-2017, 03:57 PM | #13 | |
Meh
928
Rep 781
03-17-2017, 08:31 PM | #14 |
Rep 368
03-21-2017, 10:37 AM | #15 | |
Rep 281
UltraMagneticAL927.50 |
03-27-2017, 07:27 PM | #16 |
BimmerPost Supporting Vendor
2005
Rep 6,916
I went back to stock set up guys, will probably do an alignment to get some more camber and see if I can zero out the rubbing, I'm slammed so even on stock under heavy load I will rub, that's 600 lbs extra in my car going over some very uneven payment and dips in the road. (NY/NJ/CT/PA) roads suck LOL
