E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Spec 3 Clutch Bleed Issue
Reply
      03-11-2017, 03:34 PM   #1
victor247
Drives: 08 335i E93, 2012 GTI KO4
Having an issue bleeding the clutch.
I had a friend pump while I opened and closed the bleeder. It drops to the floor once I open the bleeder and close it. Then I have my buddy pump it. There is too much movement as if not engaged then halfway through, it just gets too hard to press but it's not at the floor yet. And it gets stuck there. I'm afraid of breaking something.
2008 335i E93 Single Turbo
Join our national street racing community!
https://www.facebook.com/groups/streetracingcreed/
https://wwwStreetRacingCreed.com
Instagram - StreetRacingCreed
      03-12-2017, 12:35 AM   #2
Milan
Drives: F80 M3
you might have an air pocket still...
17 M3 Comp
      03-12-2017, 12:40 AM   #3
victor247
I plan to pick up a bleeder gun and try that. If that doesn't help, I have seen people use a siringe to push the fluid up through the system and push the air out through the top.
      03-12-2017, 04:52 AM   #4
Brule
Australia
830
Drives: 2007 335i e92 6spd man
You can bleed it by yourself if your willing to have a go.
I put a stick/vaccum cleaner pipe against the drivers seat and used the electric seat moving it hard forward so the clutch is depresses, bleed the air, Then move the seat back and let the clutch out and repeat till the clutch is fully working
      03-12-2017, 04:55 AM   #5
Brule
Australia
830
You only bleed a tiny bit of air each time.
Your mate should let you know if the pedal feel is slowly going down and you should nip the bleeder back up over and over till it's sweet. If it's on the floor cause the bleeder is open well that means your letting the fluid out so no pressure can build
      03-12-2017, 08:29 AM   #6
feuer
feuer's Avatar
Drives: wife crazy!
Why is the title Spec 3 Clutch bleed issue? Anyhow, you either need a brake bleeder or a vacuum pump. Pressing the clutch pedal to pump it will not do it. They also sell remote clutch bleed lines which makes it easier.
      03-12-2017, 08:41 AM   #7
victor247
I have done many clutch bleeds, this one is the mother of PITA. Half way through, it's close to impossible to depress the clutch or it feels like I'll be braking things like linkages.
      03-13-2017, 12:02 AM   #8
victor247
I ended up using a bleeder gun. Made sure it was holding 15psi without any bubles coming through. Then topped off the fluid and opened the bleeder screw. Some fluid came up and so did some bubles but then it was all fluid.
      03-13-2017, 09:50 PM   #9
victor247
All set. Thanks guys.
      03-14-2017, 12:41 AM   #10
NW 335i
Drives: 335i 6MT
Bleeder gun as in a Mityvac?
      03-14-2017, 01:24 AM   #11
victor247
Yes. Not exactly the mityvac but a gun very similar to it.
Reply
e90post
