Broken OBD-II port
03-17-2017, 07:51 PM | #1 |
Rep 338
Broken OBD-II port
So I had a tracking device (Metromile insurance) plugged into my OBD-II port and accidentally kicked it today, which broke the OBD port's connector off from the car
Looking closely the plastic is definitely broken. I suppose I could try to glue it but it's kinda tucked away and hard to get to. Any ideas? |
03-17-2017, 07:57 PM | #2 |
Rep 9,209
You can replace it! Is made out of two pieces that snap together and then are screwed in by two little screws. I have done few of these. Look here: http://www.e90post.com/forums/showthread.php?t=1093984
dancing__narwhal141.50 |
03-17-2017, 08:01 PM | #3 |
Rep 589
http://www.realoem.com/bmw/enUS/show...diagId=61_1764
Verify that those are the correct parts for your VIN, but you hopefully just need 61136954580. |
03-18-2017, 11:35 AM | #5 |
Rep 18,823
It's a BMW... you are SUPPOSED to drive it the way your insurance company doesn't want you to. Why in God's name would you let your insurance track you?
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
dannyhavok132.50 |
03-18-2017, 02:23 PM | #6 |
Rep 338
Metromile insurance only tracks miles not driving habits. You pay per mile rather than a fixed annual rate so you save money if you drive less.
03-18-2017, 02:54 PM | #7 |
Rep 338
03-19-2017, 12:43 AM | #8 |
Rep 5,023
03-19-2017, 12:47 AM | #9 |
Rep 338
03-19-2017, 12:38 PM | #10 |
Rep 165
Drives: 2011 335is
You may want to get a cheap obd ribbon cable from Amazon so you can tuck the reader away where you won't kick it.
03-19-2017, 01:12 PM | #11 |
Normal Person
148
Rep 862
Drives: 2011 E90 335i
I've had to replace the OBD port twice. Bad design or weak plastic where the plug meets the mounting base, makes it easy to break there.
05-07-2017, 07:44 PM | #12 |
Rep 338
I'm finally getting around to fixing this and I can't seem to get the old OBD connector off. I have removed the kick panel and trim pieces that are blocking it but I cannot get the pins out of the existing connector.
Is there some kind of special tool I need? |
05-07-2017, 09:21 PM | #13 | |
BMW Enthusiast
35
Rep 79
Drives: 07 335i E92
I couldn't find the tool anywhere and when I asked the dealer, they said it would take them a few hours to do the job. Which to me just meant that they were trying to make more money off me. It's been a few months and I've just left it as is. I got an OBD II extension cable instead and have it tucked away whenever I need to attach anything to it. |
05-08-2017, 10:12 AM | #14 |
Rep 338
I spent an hour last night trying to get the pins out and I basically destroyed the original connector doing so. I tried a small screwdriver and sewing needle and still could not get them out. I could really use some advice here!
05-09-2017, 05:27 PM | #15 | |
BMW Enthusiast
35
Rep 79
Drives: 07 335i E92
Anyway I asked for them to leave the broken OBD port so that I could take some pictures in case it would help someone. View post on imgur.com View post on imgur.com There seems to be a grey piece that slides in to the OBD port from one side. I think you may need to release that before releasing the pins. You may require a tool such as this: http://www.lislecorp.com/divisions/p...1&category=14/ Hope this helps. There's a post by a member replacing a broken OBD port on a E36, but it has some valuable info. Also, if this is against forum rules, please edit the following as it points to a post on another forum: https://www.bimmerforums.com/forum/s...4#post24925314 Last edited by dj_aj; 05-09-2017 at 05:41 PM.. |
05-09-2017, 10:22 PM | #16 |
Rep 338
Thanks! I did actually pull out that grey piece. You can see from these photos that I've actually managed to rip the entire top off from the rest of it. Yet still the pins are holding on somehow
05-10-2017, 07:13 AM | #17 | |
Rep 1,289
05-10-2017, 03:42 PM | #18 | ||
Rep 338
05-30-2017, 03:40 AM | #19 |
Rep 338
Bump! I could still use help with this. Any advice on why kind of tool I need to get the pins out from the connector housing? I've tried a sewing needle with no luck :/
06-07-2017, 04:11 PM | #20 |
Rep 9,209
I used watch repair mini screw driver to pry them out. Same kit as this http://www.globalindustrial.com/p/to...FRK1wAod7L0Cpw
06-27-2017, 03:56 PM | #21 |
Rep 338
In case anyone is wondering, I was never able to get the pins out of the original connector. Instead, I bought a OBD Y-adapter on Amazon such as:
https://www.amazon.com/dp/B00W2X91F8..._6y4AbU2Eonak6 Thankfully the original connector was still functional, so I plugged the adaptor into that. I then mounted one end of the Y-adapter using the screws from the original connector and tucked away all the excess cabling before reattaching the plastic trim/cover. It looks good as new now and you'd never know unless you took the thing apart. Bonus is that I could use the second end of the Y for a dongle or tracker if needed. |
