M3 LSD installed on my 335i. Lots of pics.
03-20-2017, 10:29 AM | #1 |
Rep 420
I recently had my friend (Engineered Mechanic Mike) do a M3 LSD swap into my 335i. I am a single turbo N54 with 6MT, and put around 700hp to the ground. I wanted to do a LSD swap because even with 265 R888R's out back, most of second and all of first gear were useless. I do most of my work myself when time permits, but since this involved shortening the driveshaft and changing bushings I asked Mike to take it on (he is a mechanical engineer by trade, and knows his BMWs!)
I decided to do the M3 LSD swap instead of a Wavetrac/Quaife for a few reasons:
This wouldn't have happened without the excellent threads by Theconnman2 (http://www.e90post.com/forums/showthread.php?t=1341843) and GeorgeSmooth (http://www.e90post.com/forums/showthread.php?t=321625). These guys rock, and hopefully this thread adds to their already awesome work. I started by researching all the parts they listed, and then by buying off eBay and craigslist. I also found some parts at online scrap yards, but was able to find cheaper stuff on the other two sites. Any of them should work though, so do whatever you find easiest. Final parts list (for me). Your list will be different!:
So my total for parts was $1231, labor was $600, and driveshaft rework was $100. To put one of the other LSD options in comparison, we will just stick to parts/rework cost without bushings. Labor will be really variable. On N54Tuning, the Wavetrac for my car (2009) would be $2694.00. Then you send back the core, and total is $1499+$35 shipping + $85 core shipping return = $1619. So I only saved about $288 to start with, but in the process I got upgraded and beefier half shafts, an upgraded and beefier axle, and a much beefier LSD/pumpkin with heat spreader than the LSD replacements for the 335i pumpkin. Seems like a no-brainer to me. OH, and I get to sell all my old parts and probably get a lot of money back! So now that the costing/parts are done, here are the install pics. We will be doing a writeup soon as well, but this install is a bit more difficult due to needing bushing removal tools and a good way to remove axles (air hammer in our case). Pics: On the "lift" and ready for swapping. Giant nuts on the 335i driveshaft to diff connection. These require a really big wrench. Make sure you measure your driveshaft lengths BEFORE removing anything, as you will need those lengths to have the new driveshaft reworked. Center support bearing unbolted M3 diff/driveshaft on the left, 335i on the right. Notice how much bigger the M3 differential is, and how much more beefy the heatsinks are? Here you can (kinda) see that the front half of the M3 shaft is longer than the 335i one. This is why it needs to be reworked by a professional driveshaft shop. This is after the driveshaft was reworked. The front flange from the 335i is different than the M3, so the M3 front shaft needs to be cut down and shortened, and then have the 335i flange welded on. Here are my lengths, but yours will be different. Do not use these measurements before checking yours personally. Hard to tell here, but the flanges are slightly different sizes. Need to make sure you 335i one is used for the finished driveshaft. These are the two center support bearings. M3 on the left, 335i on right. You will need to put your 335i one on the driveshaft you are having reworked/balanced. The M3 one sits lower, so can't be used or your angles won't be right! M3 axle (bottom) vs 335i axle (top). The M3 half shaft is MUCH beefier. Old bushings coming out... New (stiffer) bushings going in... M3 diff in place. Notice the giant heatsink on this guy. Much nicer than the 335i pumpkin, which you won't get if you just do a Wavetrac/Quaife swap... That's it! The car now gets some traction in 1st, and hooks pretty well in 2nd. Way better than it was before. Also feels substantially better in corners than it did before the swap. I know a lot of people argue that a LSD isn't needed since we have the BMW braking assist to "simulate" a LSD, but to be honest it feels totally different. Well worth the money. Hope this thread helps! Josh
Lots.
17
zero2sixtyZ954.00 Chris@VargasTurboTech1934.50 Miller335290.50 terryd5150507.00 vtl1496.00 Bimmer 808170.00 medicineman8431.50 pinder9143.00 6ixSpd6034.50 BKBMW335I156.50 AlexN176.00 SeanCon101.00 allcaps5512.50 mightgodn5464.00 StradaRedlands5030.50 Jaronbwall284.50 johnnyorange58.50 |
03-20-2017, 10:39 AM | #3 |
Rep 2,679
Drives: e92 + f15
Great writeup! Just to ask, you said the diff is from a DCT but the driveshaft is from an SMG? Is that a typo or are we pulling between E46 and E9X parts?
03-20-2017, 10:42 AM | #4 |
Rep 420
Good question. The driveshaft was sold as from an "e90 auto SMG" on eBay. I do not know exactly what he was referring to, but I believe he just misnamed it and it was from a DCT car as well. It looks like any of the e90/92 driveshafts from a M3 should work for a 6MT build, as they need to be shortened either way. I changed my post up top to stop anyone else from being confused.
Lots.
03-20-2017, 11:14 AM | #5 |
Rep 1,532
Excellent write up. We agree this is a very good value, plus you get the upgraded shafts. The other thing is that the input shaft on the 335i differential is no where near as strong as the M3 version; we broke ours at the track. The M3 is stronger all around. I'll be doing this on my personal car. Thanks for posting!
Chris Last edited by Chris@VargasTurboTech; 03-20-2017 at 12:51 PM.. |
03-20-2017, 03:26 PM | #7 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Great info and write up. I wonder how this would work out on a DCT 335is since the ratio is 2.56? The TCU wouldn't be happy.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
Rube75.50 |
03-20-2017, 04:20 PM | #9 |
Rep 113
People have put the manual lsd in that has a ratio of 3.85 in the manual 335i. It works but expect low gears to be pointless and rpms to be higher on the express way (and everywhere).
03-20-2017, 07:25 PM | #11 |
Rep 1,525
neuroclast, do you have the ediff coded out? If not, get it done, as the job is incomplete until the ediff is coded out. Topgear does a fine job for a reasonable fee.
03-20-2017, 07:48 PM | #13 |
Rep 113
It's should be cheaper and easier for your to just do a lsd in your stock pumpkin!
From my experience and from what I have read, this is not needed. If the LSD is doing its job the e dif should never come on.. it never has come on in the year I've been driving it. If I am missing somthing please let me know! This is just from personal experience but I will be the first to tell you that I don't know everything and am always willing to learn.
Alpine White E92 335i Precision Raceworks Inlets - VTT Outlets - VRSF Downpipes - VRSF 7" FMIC - M3 Differential - F30 Front Brakes - ER Oil Cooler - CSF Aluminum Radiator - ER Chargepipe w/HKS - Koni Yellows w/ SWIFT Spec R |
03-20-2017, 08:55 PM | #14 |
Rep 1,525
What kind of power are you putting down connman? Asking since I have but 530 at the wheels and unless I click the button the traction light flashes. At 700 whp neuroclast's will likely kick in constantly.
03-20-2017, 09:01 PM | #15 |
Rep 420
It does come on in first if I get on it, but to be honest that's okay with me. If I didn't have R888R's and warm tires, pretty much anything is going to go up in smoke at these power levels. I just turn on DCT when I plan on getting on it, or turn off traction control entirely when planning on doing something stupid. Other than that, I haven't found a need to code it out. But I haven't had the LSD in long either.
Lots.
03-20-2017, 09:17 PM | #16 |
Rep 113
Currently at mid 4s looking for 5s this summer. I guess I will see if it is a problem for me then. Do you have new bmw fluid in it when you installed?
03-20-2017, 09:57 PM | #17 | |
Rep 1,525
The coding is under 100 bucks, and we'll worth not needing to constantly turn the DSC off. |
03-21-2017, 03:28 AM | #18 | |
Rep 165
Drives: 2011 335is
I myself have the dct with the final drive changed to 2.81 it does not cause codes or major problems that I have noticed. but the tach does get a little confused when shifting gears. Always moving from where it thinks the engine should be to where it actually is. |
03-21-2017, 04:50 AM | #19 |
Rep 6,285
Did you have any vibrations at all? Unfortunately I had a massive saga with my M3 driveline install the shop who performed the dirveshaft swap checked balanicing twice but it still vibrated. I had it sent to another workshop who found it to be out slightly and this made a huge improvement but still not 100% vibration free...
How do you find the diff bushings, lots of guys state that these cause lots of extra NVH. This was on the N5X enthusiasts FB page a few days ago https://www.facebook.com/INEVERL0SE/...0796188438694/ Last edited by DR-JEKL; 03-21-2017 at 04:55 AM.. |
03-21-2017, 06:27 AM | #20 | ||
Rep 960
03-21-2017, 08:36 AM | #21 | |
Rep 546
The OP has the purple powerflex which are much more forgiving and based on reviews I've seen for these bushings in the E9X M3 forums, the added NVH with these should be minimal As for the driveshaft vibrations, keep in mind that you could always have a custom carbon fiber driveshaft made by The DriveShaft Shop. It's pricey, but its a lighter, stronger, 1 piece DS... http://www.e90post.com/forums/showpo...&postcount=322 |
03-21-2017, 12:44 PM | #22 | |
Rep 420
Lots.
Tags |
335i, differential, half shafts, lsd, swap |
