04-18-2017, 11:47 AM | #1 |
Joint Chiefs of Staff
24342
Rep 191,109
Now Available Agency Power M240 B58 Air Intake
One of the easiest ways to gain horsepower and improve your throttle response on the BMW 40i B58, turbocharged engine, is with an air intake kit. Agency Power's new short ram air intake kit for the M240i, 340i, and 440i is a great first modification to do. The intake kit is a complete replacement for the OEM air box. The kit includes a new aluminum intake tube with CNC machined MAP sensor mount, precision cut heat shield with mounting tabs, and a new high flow air filter. The MAP sensor mount has been CNC machined out of 6061 aluminum to retain the factory fitment for proper readings. It is than TIG welded to the aluminum intake tube for proper placement. The main part of the intake is the high flow air filter. It features an inlet on the end cap to allow for an even larger volume of air to come through than a standard cone filter. The design improves air filtration while increasing air flow. The air filter is finished off with the Agency Power text and AP logo on the rubber end cap. The heat shield is water jetted from aluminum with rubber trim to provide a secure fit and seal when the hood closes. It is designed to prevent direct hot air from the engine being sucked into the filter. Each heat shield features the AP logo neatly cut out from the shield panel for added style. All parts are finished in a matte black powder coat for an OEM look while the cylindrical air filter features a blue element matching to the BMW Roundel logo. With the new air filter, your turbocharger can breathe better than the factory intake allows. This is noticeable as you step on the accelerator and hear the turbo work (sucking air noise). Release the throttle and the factory blow off valve noise (whoosh) is more audible and keeps you entertained through the gears!
Features: • Aluminum construction • CNC machined MAP sensor mount • Black powder coat for OEM look • Reusable high flow air filter Fitment: • BMW M240i F22 • BMW 340i F30 • BMW 440i F32 Note: • Heat shield was designed on the BMW M240i chassis and may require alterations or removal to work on the 340i and 440i. Part Number: AP-M240i-110
04-19-2017, 01:04 PM | #2 |
24342
Rep 191,109
04-20-2017, 10:09 AM | #4 |
24342
Rep 191,109
No dyno results posted by agency power yet. Other open air intakes have shown 5-8 whp gains on the dyno
04-20-2017, 09:16 PM | #7 |
24342
Rep 191,109
I do not have any videos to compare the 2 but sound and performance should be similar.
Vyruz Reaper151.00 |
05-30-2017, 04:53 PM | #8 |
Rep 412
05-31-2017, 06:58 PM | #10 | |
Rep 412
100 dollar difference and you sell both of them. I'm looking between getting one of these two for my 2017 M240. the burger tuning intake has the option to add the oil catch can, but the agency power does not. i don't really understand what the function of it is but would you mind explaining? thank you! John |
05-31-2017, 06:59 PM | #11 |
24342
Rep 191,109
BMS is only a filter , Agency Power comes with pipe and a heat shield
05-31-2017, 08:33 PM | #12 |
Rep 412
05-31-2017, 09:29 PM | #13 | |
24342
Rep 191,109
Prices are on the website, this intake is on back order for 4 weeks.
05-31-2017, 09:32 PM | #14 | |
Rep 412
Burger intake in stock? is it recommended to get the oil catch can? if the performance is the same..is the "sound" from the upgrade the same as well? what would be the reason that anyone would want to buy the agency power intake over the BMS? and the bmw will fit my m240 fine correct? thank you |
05-31-2017, 09:34 PM | #15 | |
24342
Rep 191,109
BMS is in stock Agency Power is very popular, a lot of customers like the finish and the Agency Power intake.
05-31-2017, 10:23 PM | #17 |
24342
Rep 191,109
It does not
05-03-2018, 06:05 PM | #18 |
24342
Rep 191,109
a large shipment of Agency Power B58 intake is on its way to us
05-04-2018, 02:49 AM | #19 |
Rep 19
05-04-2018, 10:57 AM | #20 |
24342
Rep 191,109
Once we receive the new batch that is on its way we will send you your tracking number
Mathew Miles13.50 |
05-18-2018, 06:10 PM | #22 |
24342
Rep 191,109
