04-29-2017, 08:40 PM | #2 |
BimmerPost Supporting Vendor
3885
Rep 54,498
Drives: F80 M3
The version that works with coilovers is great. I don't think anyone has tried it on OEM strut and springs(at least not bought from us. I think TC has sold a few himself), but that those who has can chime in anytime.
08-06-2018, 02:31 PM | #4 |
Rep 42
Drives: 2018 BSM M2
I’m curious to hear opinions between the double adjustable TC Kline’s and the Ohlins R&T. TCK double adjustable comes in slightly higher priced, but includes camber plates whereas the ohlins don’t.
My M2 is primarily a daily driver with 10-15 track days at the Nürburgring, Hockenheim, and Spa along with high speed runs on the autobahn. Thanks in advance. Last edited by EUCSIP; 10-02-2018 at 12:45 PM.. |
10-01-2018, 08:51 PM | #5 |
Rep 2,560
Drives: Rapidly from A to B
I have tckline camber plates with otherwise stock suspension. I have them set in the middle position all the time. In that position they have about -2.25 camber. A good setting for the track but does induce a little inner tire wear on the street.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
10-05-2018, 03:52 PM | #6 |
Rep 42
Drives: 2018 BSM M2
Any reviews on the TC Kline Coilovers themselves? Only seen a couple post...
10-05-2018, 04:13 PM | #7 |
Rep 8
I have them
They are great. The config you want is the Double Adj rear, and Single Adj Front. The DA fronts are quite noisy.
You will want to adhere to TC's specs for setup with respect to Alignment and damper settings. Don't assume you know better. He's done extensive testing with the M2 and this setup. He knows what works. I've done 4 track weekends so far and they perform brilliantly, and are just fine for the street.
2017 MG M2
BM3 OTS Stg2 93, CSF IC, Fabspeed 200 DP, MPE TCKline Suspension, Camber Plates Blue Raspberry 3M Wrap |
10-05-2018, 04:37 PM | #8 | |
Rep 42
Drives: 2018 BSM M2
10-05-2018, 05:21 PM | #9 |
Rep 8
TCK
Yes, you can get to them with wheels on.
2017 MG M2
10-05-2018, 07:35 PM | #10 |
3885
Rep 54,498
Drives: F80 M3
Yes, you can get to both adjustments. You may have to jack the car up to get to the rebound adjustment, however.
Photos below are the newly designed rear double adjustable shocks. |
10-06-2018, 02:15 AM | #11 |
Rep 42
Drives: 2018 BSM M2
Thanks but I have a question regarding whats on your website. I dont see the option for single adj front/double adjust rear. Seems either double for all, or single for all. TC Klines website has the single/double, but havent found that combo anywhere else.
10-06-2018, 07:19 PM | #12 | |
3885
Rep 54,498
Drives: F80 M3
The double rear is to improve rear damping over the single adjustable damper. The single adjust is also very hard to adjust and removal of the shock is required. PM, email or call us if you have other questions. |
10-08-2018, 01:45 PM | #13 |
Rep 42
Drives: 2018 BSM M2
Yes I would be interested in that combination. Is the rear rebound adjusted via a Phillips screw? Hard to tell in the picture. Disregard that question, YouTube sometimes is a great thing...
10-08-2018, 10:19 PM | #14 | |
3885
Rep 54,498
Drives: F80 M3
I'll PM you pricing on the combo you are after. Share the video here. |
10-09-2018, 10:42 AM | #15 |
Rep 42
Drives: 2018 BSM M2
At ~1:35 in the video Last edited by EUCSIP; 10-09-2018 at 10:49 AM.. |
10-09-2018, 12:49 PM | #16 |
3885
Rep 54,498
Drives: F80 M3
03-08-2019, 06:16 PM | #17 |
3885
Rep 54,498
Drives: F80 M3
TC Kline Racing Camber Plates Installed
TC Kline Racing camber plates installed on M2 Competition using stock struts and springs.
-2.5 camber achieved on stock ride height using the middle setting on the camber plates. -3+ on the maximum setting but you may have clearance issues between the spring coil and the strut tower(mostly the undercoating and seam sealer). |
06-03-2019, 08:03 PM | #18 | |
Rep 632
06-04-2019, 11:30 AM | #19 |
3885
Rep 54,498
Drives: F80 M3
06-04-2019, 11:48 AM | #20 | |
Rep 632
We have track nuts here running GC plates on stock/mp suspension on M3 that still make noise. And GC plates are better than the vorshlags I had before. I was hoping these TC plates were different since they seem to be limited (am I wrong) in comparison to GC plates. |
06-04-2019, 11:53 AM | #21 | |
3885
Rep 54,498
Drives: F80 M3
06-06-2019, 09:41 PM | #22 | ||
Rep 2,560
