BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Full Adaptive ICON LED lights decoded for the US?
      04-30-2017, 09:59 AM   #1
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
So I just finished doing European Delivery, still here in Munich as I type this, and the guy that delivered my car and explained everything on the car says that, the Icon lights for the US were decoded because of some old law, so we do not get the full function and the tunnel effect of the European version. Which really sucks in my opinion. But anyway is anyone planning on deciding the decode lol? Apparently it can be done somehow.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      04-30-2017, 12:34 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
I decoded, but have not tested.
      04-30-2017, 12:41 PM   #3
phoenixbmwlife
Oh that's cool where did you get it done? Cost?
Follow me on Insta
      04-30-2017, 12:42 PM   #4
Almaretto
Almaretto's Avatar
2374
I code all my own cars and can do any Fxx-/Ixx-/Gxx-series BMW.
      05-06-2017, 01:35 PM   #5
Motorboat411
Drives: BMW 535i
By Decoding, I guess you guys are talking about Anti-Glare High Beam feature? I recall you said that these feature was disabled at headlight module level so not do-able?
      05-06-2017, 01:41 PM   #6
Almaretto
Almaretto's Avatar
2374
It is disabled on a software level for F010 with TMS/LHM.
It is not on FLE vehicles like G12/G30 or '17 F12.
      05-07-2017, 11:01 AM   #7
Motorboat411
Drives: BMW 535i
FLE?
What does it mean, No chance of coding the full Anti-Glare feature?
      05-07-2017, 11:20 AM   #8
phoenixbmwlife
All I want is the tunnel effect that European G30s have. The US spec LED Icon lights are nice as they are, but I really want the tunnel effect.
Follow me on Insta
      05-07-2017, 01:09 PM   #9
Almaretto
Almaretto's Avatar
2374
FLE?
Your vehicle has 20-50+ Electronic Control Unit (ECU) modules. They each contain various coding parameters and control different aspects of the vehicle.
FLE is one such module, which you have two (driver/passenger) for exterior lighting.
I am saying the opposite; unlike F010's, you will be able to code full VLD & NGHB on G030's.
      05-08-2017, 01:45 AM   #10
Motorboat411
Drives: BMW 535i
That's good to know, I did some coding on my current F10 as well, so I'll give it a try. Is it supposed to be relatively straightforward?
      05-08-2017, 09:39 AM   #11
Almaretto
Almaretto's Avatar
2374
Is what relatively straightforward?
Coding in general, yes. Coding NGHG/VLD, no.
      05-08-2017, 02:43 PM   #12
Motorboat411
Drives: BMW 535i
I was asking about NGHG/VLD. I did it on my F10 but it was still dazzling oncomers, so I disabled it. Are the steps procedure different on G30? Is it posted anywhere, so I can take a look?
      05-08-2017, 02:49 PM   #13
Almaretto
Almaretto's Avatar
2374
The steps are not posted anywhere.
It is closer to the F015 or '17 F06/F12/F13 in procedure (all have FLE's). VO coding alone will not work. It must be followed by FDL coding (100+ changes) to convert to EU values.
      05-08-2017, 05:52 PM   #14
DBV1
Drives: 2018 BMW X5d 2021 Tesla S
Sounds like it is extremley difficult to code if FDL coding takes 100+ changes.
      05-08-2017, 07:39 PM   #15
Almaretto
Almaretto's Avatar
2374
See F8x NGHB.
Difficult is a relative term.
It is not as simple as changing one parameter (eg: NGHB: nicht_aktiv --> aktiv), but still doable. And, there are tools to verify one did not miss one of the many needed modifications.
Plus, once you have changes figured out, you can create and use Launcher Cheat Codes to quickly apply said changes. Besides time, this way has the advantage of being able to re-apply changes if custom coding is erased when vehicle software is updated at dealership.
      05-10-2017, 02:22 PM   #16
Motorboat411
Drives: BMW 535i
Saw the document, but its referring to ECE values that are for F80. Since G30 uses a completely different headlights assembly, wouldn't the values be different?
      05-10-2017, 02:43 PM   #17
Almaretto
Almaretto's Avatar
2374
Correct. That was just to demonstrate that VO coding was not enough. Do not use those values.
      07-20-2017, 08:17 PM   #18
rekkk
Drives: 530
I'll be a test dummy. Can we do this Almaretto?
      07-20-2017, 08:21 PM   #19
Almaretto
Almaretto's Avatar
2374
Yes.
prostar10.00
      07-22-2017, 07:58 PM   #20
JCFans01
Drives: BMW 2018 G30 530e
Are the Canadian models decoded as well?
      07-23-2017, 12:48 AM   #21
Almaretto
Almaretto's Avatar
2374
Yes. Check VIN for 8S4 and 5AP.
      07-24-2017, 02:37 PM   #22
phoenixbmwlife
Once it's been successfully done with no bugs I'm ready to get mine done
Follow me on Insta
5post
