Coolant Leak
05-05-2017, 08:35 AM | #1 |
Midnight Marauder
72
Rep 379
Drives: AW 2008 335i Coupe
Coolant Leak
Hello. I recently started getting the low coolant warning on my dash. I fill it up with about 2-3 liters of 50/50 coolant then next day, i get the same warning. I filled it up with another 2-3 liters of distilled water which only last about a day before I get another warning.
Could this be the usual expansion tank leak? I will remove the undercarriage this weekend to see where it is coming from. I do get a wet spot on the floor underneath the passenger side after i park from a drive. No visible white residue can be seen looking at the engine bay from the top. It seems like it only leaks when certain pressure is reached in the cooling system and then the whole expansion tank is emptied. Has anyone had this issue? Most of the threads i searched seen only has a slow leak.. I've been driving it for about 3 days now since it's my only car and I just refill it as soon as I park. |
05-05-2017, 09:00 AM | #2 |
Maximus Decimus Meridius
1132
Rep 4,588
Well it could be quite a few things, but check all ur hose connections and I'm sure you'll find the root of the issue..
F30 335i Melbourne Red Metallic M-Sport Package |
05-05-2017, 12:48 PM | #3 |
Midnight Marauder
72
Rep 379
05-05-2017, 01:33 PM | #4 |
1132
Rep 4,588
Hmm, i'm a bit old school for matters like this and would first remove all the plastics in the way, grab a flash light and get to scopin out the area.. It may be something very easily identified, but if after looking through all the hose connections, you still don't see it, I'd probably go through the hoses and check one more time.. Those dye kits work, but IMO it's wasting money unless you really looked down through there and can't find it..
F30 335i Melbourne Red Metallic M-Sport Package Last edited by BeastMode335i; 05-05-2017 at 01:39 PM.. |
05-05-2017, 01:34 PM | #5 |
1132
Rep 4,588
Check your expansion tank, upper hose that's under the OFH, and all the other connections up top.. If nothing found, then i'd slide under the car and check the water pump area and turbo coolant hoses..
05-05-2017, 05:41 PM | #7 | |
Midnight Marauder
72
Rep 379
Was it draining out only a few liters at a time as well? How did you diagnose it was the water pump? |
05-05-2017, 07:08 PM | #8 |
Midnight Marauder
72
Rep 379
It's def leaking somewhere near the belt at the very bottom. My whole undercarriage is soaked.
05-05-2017, 07:22 PM | #9 |
Midnight Marauder
72
Rep 379
It looks like it's coming from the coolant outlet hose under the OFH. There's def oil around it and probably coolant since there's a small puddle right under the hose. It stopped dripping just a few minutes after i took off the undercarriage since the car got cold. I filled up the coolant reservoir but it hasnt leaked since.
05-05-2017, 07:24 PM | #10 |
Midnight Marauder
72
Rep 379
05-05-2017, 07:58 PM | #11 |
Midnight Marauder
72
Rep 379
05-05-2017, 08:39 PM | #13 |
Midnight Marauder
72
Rep 379
Started up the car and saw coolant drip right away from the Outlet Coolant Hose (p/n 11537541992). Anyone know of a DIY to replace this part?
05-05-2017, 08:45 PM | #14 |
Midnight Marauder
72
Rep 379
Found this replacement from a thread with the same issue..
http://m.ebay.com/itm/182218057115 http://www.e90post.com/forums/showthread.php?t=1117422 Has anyone else tried it before? I wouldnt mind replacing the whole hose but it seems like it would be a PITA.. and the aluminum piece looks nice lol. |
05-06-2017, 11:27 AM | #15 | |
1132
Rep 4,588
Also, make sure when seating the new part that the o-ring doesn't crimp, or else you'll have a huge leak once everything is put back together.. PS - I reused my factory hose for about 6 months after replacing this part, until I swapped my turbos, then I upgraded all my coolant and oil lines, and I had no issues for those 6 months, just make sure everything is nice and snug.. And to test your theory, top off ur coolant reservoir and start your car.. Point a flashlight in the direction of this item under the OFH, and you'll most likely see little drips coming out of it.. That's what mine did, and it actually leaked down right to the water pump area, which is what I initially thought it was that was causing the leak.. Luckily this cheap little item fixed my leaking woes.. Good luck..!
05-06-2017, 02:08 PM | #16 | |
Midnight Marauder
72
Rep 379
05-10-2017, 05:18 PM | #17 | |
1132
Rep 4,588
05-10-2017, 08:10 PM | #18 | ||
Midnight Marauder
72
Rep 379
05-10-2017, 08:36 PM | #19 |
1132
Rep 4,588
Honestly I just went hand tight and than about another 1/4 turn.. Just make sure the o-ring don't get crimped when installing the new one..
