Dual Zone Climate..How does it work?
04-30-2008, 08:20 AM | #1 |
Old enough to know better!
20
Rep 409
Drives: 320d M Sport, Le Mans Blue
This question is based on the assumption that the small grill under the fan control is the temperate sensor, so if I'm wrong the question is invalid. However - how can the climate control regulate the temperate of the driver and passenger zones independantly with only one sensor? My manager's A6 has a sensor grill under each dial which makes more sense (although they're that close together I doubt it makes much difference). Does anyone know if there are sensors elsewhere, and if so, what does the sensor under the fan control do?
Not a major issue, but one that has had me thinking for a while (I should get out more ).
Jon Steele
320d M Sport (E90) Le Mans Blue/18" Alloys/Bi Xenons/Climate Screen/Black, Heated Dakota Leather/6 CD Changer with Dension 500/Power Mirrors/M3 Lip Spoiler/Gloss Black Grills/Through Load, Storage pack, Lumbar Support, Smokers Deletion |
04-30-2008, 08:43 AM | #2 |
Rep 283
Drives: E93 330d M Sport Auto
Jonsteele, you need to get out more.....for sure
I am guessing that it only needs one sensor and calculates the adjustments to flow / air temp to the driver side primarily. It's possible that the CC is smart enough to calculate what it needs to do to achieve the the temp set by the dial on the passenger side by taking into account the dial setting on the drivers side and the temp sensor data....if you follow. I would imagine having 2 sensors set 6 inches apart would get the same reading. What bugs me more (I too need to get out more) is the fact that when alone in the car I feel compelled to turn both temp dials to the same setting........ it's bordering on compulsive obsession disorder. I had a Saab previously and this could be set so that the drivers temp dial would also automatically adjust the passenger temp too if required. It had 2 settings, dual or, single zone climate control. I don't think the E90 can do this? PhilR |
04-30-2008, 09:01 AM | #3 |
20
Rep 409
Don't beat yourself up about it - I too have to have both set the same (I hate it when the wife has hers different!).
Jon Steele
04-30-2008, 09:38 AM | #5 |
Rep 1,720
Drives: Mercedes C350 Coupe
Gulp. Guilty as charged your honour...
RockIt! |
04-30-2008, 09:42 AM | #6 |
Rep 8,811
04-30-2008, 10:31 AM | #7 |
Rep 80
Drives: '12 E91 318d & '16 F46 220d Xd
Gulp, you lot are weird, I have no problem with the wife having hers different, but I do set them the same when I am in the car on my own.
TimsterC
2012 E91 318d ///MSport : Titanium Silver : Towbar : Privacy Glass 2016 F46 220d xDrive Sport Gran Tourer B47 2.0d : Medeterranian Blue : Towbar : Privacy Glass |
04-30-2008, 10:31 AM | #8 |
Rep 9,915
Drives: VW T5
+ 1 Me too
04-30-2008, 10:36 AM | #9 |
20
Rep 409
perhaps we should send a copy of this thread to BMW R&D - proof that they need to revise the design .
Would it just be an update to the software?
Jon Steele
04-30-2008, 11:07 AM | #10 |
Right Responsible
58
Rep 1,646
The Solution
Try one of these BMW dual-zone temperature lock's. Works a treat
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys. |
04-30-2008, 11:21 AM | #11 |
Rep 2,426
Drives: E93 335i M-sport
lol nutters
04-30-2008, 11:43 AM | #12 | |
Rep 2,047
When I'm on my own in the car I too always change them together to make sure they are the same!
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport |
04-30-2008, 11:57 AM | #13 |
Rep 1,130
the benz have the 2 versions of the climate control.. one has the knobs for the temp control, whilst the more expensive system has the digital stuff and that adjusted both from what i remember..
the VAG cars, you just push the temp and hold and it matches the passenger side to drivers side. |
04-30-2008, 11:59 AM | #14 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
I end up turning both up together too!
997.2 GT3
04-30-2008, 12:57 PM | #15 |
Rep 5,080
Drives: 530d
Another guilty temperature controller here.
Gone: Fiesta - Focus - E46 320dSE - E91 330dMSport - E82 135iMSport - R55 JCW Clubman - M135i Now: 530d |
04-30-2008, 01:23 PM | #16 |
Rep 8,811
Are we nutters or are the designers of the separate controllers nutters?
04-30-2008, 01:26 PM | #17 |
Rep 5,080
Drives: 530d
Well as it's my car the temperature will be set how I want it.
04-30-2008, 03:31 PM | #19 |
Rep 33
+1
And I thought I was the only one to get all OCD on the temp dials, drives the gf nuts. The Alfa 147 has a button marked "mono" that locks the setting together. Clearly designed by a bloke. |
04-30-2008, 03:33 PM | #20 |
Rep 199
I had a 1 hour drive home tonight and tested my resolve by setting the passenger control to 17.5 degC as opposed 18 on the drivers side. It was painfull but I was able to avoid temptation.
04-30-2008, 03:36 PM | #21 |
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
Seeing as everyone is confessing to this .......I'll own up as well. OCD is alive and kicking on here then But it is SO annoying if the temperature reading is NOT the same on both sides. Shit how sad.
04-30-2008, 04:12 PM | #22 |
Rep 2,811
Drives: Jaguar XE P250 HSE
Also guilty
But I also make sure they don't read 0.5 |
