BMW M2 Forum > Regional Forums > AUSTRALIA > Speed limit displayed?
      05-09-2017, 03:13 AM   #1
Prodigy.
Prodigy.'s Avatar
Australia
699
Drives: ///M2
I was perusing Carsales as i tend to do and noticed an M2 advertised at a local dealership. One of the pictures was of the instrument panel and it shows a 50km/h speed limit sign on it. I didn't think we had this function in Australia or do we? If so how do we activate it?
      05-09-2017, 05:01 AM   #2
Aust350z
Aust350z's Avatar
Australia
243
Drives: F87 M2
My My17 has it. Very accurate as well.
      05-09-2017, 05:20 AM   #3
Prodigy.
Prodigy.'s Avatar
Australia
699
Drives: ///M2
Yeah found out it apparently is only on Nov 16 onwards production but just in case is there a setting somewhere that activates/deactivates this feature? Is it visible at all times or only when you are using the navigation?
      05-09-2017, 05:21 AM   #4
DoggieHowser
Drives: F87 Pure F20 125i MSport 2017
My 2017 build 125i M Sport has that. I believe it is enabled by default in iDrive settings.
Once enabled, you use the "BC" button on the left control stalk to cycle through the displays (average fuel consumption, instantaneous fuel consumption, range, date etc)
I'll let you know when my M2 arrives. I expect it would be the same way.
      05-09-2017, 05:46 AM   #5
Prodigy.
Prodigy.'s Avatar
Australia
699
Drives: ///M2
Do you know what setting it's called in the idrive?
I have turned a few options off that are available through the BC button but it looks as though the earlier build dates definitely miss out on this feature.
      05-09-2017, 10:10 AM   #6
Aust350z
Aust350z's Avatar
Australia
243
Drives: F87 M2
Spot on.
Always on regardless of Nav. Dealer said they've coded it back-in. Don't think it's hardware related.
      05-10-2017, 01:50 AM   #7
DoggieHowser
[IMG]http://i965.photobucket.com/albums/a...ps2rrmqtre.png[/IMG]
Prodigy.698.50
      05-10-2017, 03:08 AM   #8
Prodigy.
Prodigy.'s Avatar
Australia
699
Drives: ///M2
Thanks mate, i definitely don't have that 'Limit Info' option in my settings menu. Strange why they only added it on the later model builds as the camera on the windscreen is obviously there on my car.
      05-10-2017, 04:19 AM   #9
DoggieHowser
I was told that the software was buggy and it didn't read the signs correctly initially so they might have disabled it at first
      06-07-2017, 10:59 PM   #10
///M-pressed
Australia
276
Drives: E46 M3, F82 M4
Same thing I heard. Anyone know how to code it back on? Mine is a July 16 build.
F82 M4 | 6-speed manual | PP performance Stage 2 tune | Re-valved Bilstein B16s | VRSF midpipe | OEM CS front splitter | OEM GTS hood | OEM M-performance rear diffuser| Evolve tuning catless downpipes | 310rwkw (415rwhp)
      06-08-2017, 02:27 AM   #11
Prodigy.
Prodigy.'s Avatar
Australia
699
Drives: ///M2
I checked with the dealership and they confirmed with me it can't just be coded on to cars built prior to Nov. I believe there is an additional module required for it to work.
If you can prove them wrong and get it to work please let me know.
      06-08-2017, 07:42 AM   #12
///M-pressed
Australia
276
I'll see what I can do =)
Prodigy.698.50
m2
