Auto Torque Limits
05-12-2017, 10:17 PM | #1 |
Rep 112
Auto Torque Limits
So, doing some research, and im trying to figure out if there was any variation on the torque limits over the years, and trying to figure out what is safe for mine.
I have a 2010 335i auto. and my goals are to basically get into the 600HP range. which will have quite a bit more torque than stock too. I want to be able to launch safely at the track, and just when joy riding in the car. Ive read different things like its 335, or 435 torque. Plans for performance mods go sort of in this order. tial BOV, injen intake, and high flow downpipes, Flash, JB4, and looking to run stage 2 on 93 oct, LSD. Eventually will like to upgrade the turbos, so i can see 600 or so hp and 500 or so torque. My cars got about 54k on it, and i'd like to not break stuff at the track. Are there parts other than the transmission that need to be upgraded so i dont break something at the track with that HP range? It will be a year or so before i get everything purchased, and i should be able to have a built transmission in a couple of years, Whats a good shop to build the transmission when it breaks? I read some stuff about level 10, but have not really seen anything mentioned about other shops. |
05-12-2017, 10:48 PM | #2 |
Rep 602
05-13-2017, 01:25 AM | #3 | |
Rep 112
also will these cause any OBD 2 Scan issues? |
05-13-2017, 02:26 AM | #5 | |
Rep 1,693
You can limit 1st gear torque with the DME flash with MHD. |
05-14-2017, 12:43 PM | #6 | |
Rep 2,825
the most stressful thing you can do to your transmission and driveshaft is frequently off the line launches. if you avoid doing this often the transmission should last. |
05-15-2017, 10:46 AM | #7 |
MT or bust!
170
Rep 289
Drives: 2010 E90 335i M Sport, 6MT
thanks again captain obvious. what would E90 post do without you?
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
05-15-2017, 10:59 AM | #8 |
Rep 2,825
Bmw doubles983.50 |
05-15-2017, 09:33 PM | #9 |
Dream crusher
984
Rep 2,421
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
STR8-6IX537.00 |
