05-15-2017, 11:18 AM | #1 |
Joint Chiefs of Staff
24342
Rep 191,128
BMW B46/B48/B58 Tune Comparison
Today; I would like to write about the different piggyback options available for the BMW new F chassis B48/B58 engines. This market is over-saturated with tunes priced from a couple hundred dollars up to a couple thousands. Not all tunes are equal, which ones are worth it and which ones are not? Read this post and decide for yourself. Burger Tuning (BMS) B48/B58 Quick Install/Uninstall JB+ How: Burger Tuning JB+ connects to Tmap sensor only. This is the simplest B48/B58 tune on the market. Pros:
Cons:
Price $199 Burger Tuning (BMS) B48/B58 JB4 stage 2 How: Burger Tuning B48/B58 JB4 stage 2 connects to TMAP, MAP and OBD. It also comes with flex fuel connectors for E85 users. Pros:
Cons: Long install time (45 minutes). Price: $529 Dinan B48/B58 Sport Performance Tuner: How: Dinan B48/B58 sport performance tuner connects to MAP and Tmap sensors. Pros: Easy install (5-10 minutes) Adjustable boost Bluetooth capability Cons: Does not suppress CEL code from high flow downpipes No datalogging capability No code reading capability Price $299 Active Autowerke Active8 Tune How: Active8 connects to boost pressure sensor, Manifold pressure sensor, crank position sensor ( rpm pick up point) Pros:
Cons:
Price: $729 Thank you for reading. Dinan Stage 1 will be added to this comparison next.
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 06-01-2017 at 04:01 PM.. |
05-16-2017, 05:15 PM | #3 |
24342
Rep 191,128
06-01-2017, 04:01 PM | #4 |
24342
Rep 191,128
Active 8 added to the list, Dinan tune next
06-29-2017, 10:36 PM | #5 |
Rep 18
I guess this should be updated since the new firmware for the JB4 no longer automatically suppresses CEL code from downpipe. Confirmed on N54tech and I got CEL on my ride home from work, easily deleted through the app though
06-30-2017, 12:03 AM | #6 |
24342
Rep 191,128
This thread will be updated soon with a new tune added and JB4 info fixed.
02-17-2020, 12:35 PM | #7 |
Rep 6
So will BimmerLink delete the CEL code for good if I get one of these? I’m new to BMW. Thanks in advance!
02-20-2020, 11:11 AM | #8 | |
24342
Rep 191,128
If you want to hide the code for good, get a flash tune like Bootmod3
03-13-2020, 10:31 AM | #9 |
Rep 56
Thanks for posting this! Was going to make my first post asking about this but glad I found this after I registered.
Picking up a mint 17 240iX tomorrow and looking at all the different options. Will be my first time putting a software tune on. My main question is a comparison between the Dinan offering and AA8. I know the dinan has a bypass option on the fly but does the AA8 provide this capability as well? Do they throw any CEL codes during their usage (on stock internals/exhaust). Performance for dollar and warranty? Lastly, what is the estimated total cost doing the software and a propertune at a local dyno (Bimmersport is the authorized AA and Dinan installer). Many thanks! |
03-13-2020, 11:11 AM | #10 | |
24342
Rep 191,128
Neither of these tunes will throw a check engine light. If warranty is important to you, Dinan is the way to go. If you want performance/dollar checkout Bootmod3, Jb4 or Active8 flash
03-13-2020, 01:47 PM | #11 | |
Rep 56
Looking at active as my warranty is up soon on the car in about 6000km. How easy is it to select between OE, stage 1 and stage 2 once installing active flash? Thanks |
03-13-2020, 07:04 PM | #12 | |
24342
Rep 191,128
It takes a couple minutes to flash a new map
