BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > HELP! F21/F22 headlight conversion question
      05-15-2017, 04:58 PM   #1
JohnBoyMinster
Drives: M135 F21 With F22 Front
Hi all
Long time lurker, new poster... thank you in advance for reading this..
So, I bought an F21 M135i that had an F22 conversion done (poorly), main problem being very shoddy wiring work on the headlights, everything works apart from full beam - the lights will only 'flash' when I have the drl or sidelights on (pretty sure it's just flashing the dipped beam).
So - looking for the fix. My car came with LED lights out of the factory (15 reg LCI) and now has F22 Xenons fitted.
Any advice to help get the full beam working?
      05-16-2017, 04:53 PM   #2
JohnBoyMinster
Can anyone help?
      04-09-2019, 03:31 PM   #3
tonyhhandler
Egypt
Drives: f30 328i
same problem with headlights
Originally Posted by JohnBoyMinster View Post
Hi all
I have the same problem, how have you fixed it ?
      04-15-2019, 09:14 AM   #4
88tuning.id
88tuning.id's Avatar
Indonesia
39
Drives: E39 520i Msport
Hi all
you sure the wiring job is perfect?
if yes, then the rest is only coding work
Instagram: @tafikhulafaa & @88tuning.id
      04-15-2019, 05:41 PM   #5
tonyhhandler
Egypt
Drives: f30 328i
Hi all
what is the required coding ?
      04-15-2019, 07:01 PM   #6
88tuning.id
Indonesia
39
deleting LED lamp option and adding Xenon options to the VO if it's the case.
1addicts
