PCV venting to atmosphere will work.
05-01-2008, 11:24 AM | #1 |
Rep 4,726
So I've wanted to vent to atmosphere through a catch can just to insure there's no chance of any oil getting in after I get a clean intercooler in there so I did some "testing" yesterday to insure it's possible (not requiring vacuum to assist, didn't expect so but it's good to check). This "testing" consisted of taking the heater hose routed to the valve head and holding it out the window while flooring it down the street.
Still plenty of flow. If you want to do this you need to know a few things A: it's very Illegal; B: you should do it through a catchcan to minimize the oil you spray where ever it's venting; C: You need a filter on the end to insure no particulate gets sucked backed into the valve head, this is not an option (or not optional, before I get jumped on, whichever you prefer)
05-01-2008, 06:14 PM | #2 |
Perf BMW mag issue 147, 159
415
Rep 6,803
thats how i had my catch can set up on the lexus...
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
05-01-2008, 06:20 PM | #3 | |
Rep 384
Did this on my Eclipse years ago, had a little (very little) K&N Filter on the end. |
05-02-2008, 02:03 AM | #4 |
Rep 78
I had mine vented to the atmo on my SRT4 as well with a filter too. i went for a dyno session and noticed i was a couple hp short of where i felt i should have been. dyno operator suggested i reroute it back to the intake (which we did). ran it again and picked up 10whp.
just throwing my experience with this out there. |
05-02-2008, 02:15 PM | #5 |
Rear wheel drive fanatic
53
Rep 604
Drives: M3 E30-1M-M4
Not bad.
05-02-2008, 04:41 PM | #6 | |
Rep 1,659
03-02-2010, 10:40 AM | #8 |
Rep 1,311
That is what I'm doing to http://i407.photobucket.com/albums/p...s/FILE0072.jpg
03-02-2010, 11:49 AM | #9 |
Rep 19
While this is true, vacuum on the crank case provides the benefit of pulling pressure out of the engine freeing up internal restriction. It will also help the rings seal. We only suggest the VTA type systems on REALLY gross engines where the amount of blowby becomes such an issue that the performance gains arent as important.
03-02-2010, 12:57 PM | #10 |
Rep 1,184
Si there is vacuum (or at least depression) in the intake pope to the turbo.
This means that the filter + airbox is restrictive! in a free flow intake there is no depression |
03-02-2010, 01:05 PM | #11 |
Rep 1,659
03-02-2010, 01:18 PM | #12 |
Rep 1,311
But even (or especially) with a free flow intake there is a high flow air stream, which will suck crankcase vapours with it if connected.
03-02-2010, 01:30 PM | #13 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
Under boost(acceleration), there will be vacuum conditions in the pre-turbo intake piping...however under decel/idle there is no vacuum in the intake pipe. The crankcase vapors are routed to the intake manifold under no-boost conditions via a by-pass valve built into the valve cover. That's why a catch can will help prevent oil build-up in the charge pipes, but will not completely eliminate build-up on the valves themselves since under no-boost conditions crankcase vapors will still be routed to the intake manifold.
I think the best of all worlds would be to get the Macht Schnell DPs with EGT bung and route crank vapors to the exhaust...that way you still get the benefit of evacuation of the vapors from the crank and they still get passed through the secondary cats, assuming you have them still. |
03-02-2010, 01:49 PM | #14 | |
Rep 1,659
03-02-2010, 04:48 PM | #15 |
king of the hills
92
Rep 2,915
Yes, that way no vapors at all back into your intake tract. Though the 90° inlet into the exhaust is not ideal, usually the kits for PCV exhaust evacuation have a 45° adapter to weld onto the exhaust/DPs. However it does have the potential to gum up the secondary cats though...probably best if completely. Others have built specific vacuum pump systems for this as well, though those are usually only used in drag racing conditions, where they can actually have an affect on HP (think 1000+ hp engines here).
Do a google search, you will find many applications in Supras/Nissans/Vettes/VW's etc. edit: Here are some good thread about it http://www.honda-tech.com/showthread.php?t=1199935 http://forums.vwvortex.com/zerothread?id=4387972&page=1 Last edited by raceyBMW; 03-02-2010 at 05:19 PM.. |
03-02-2010, 05:43 PM | #16 | |
Rep 1,659
03-07-2010, 07:03 AM | #17 |
Rep 1,432
Can you compare the crankcase vacuum using exhaust scaveningen with the vacuum by the stock arrangement? The vacuum is needed for freeing up the engine.
03-07-2010, 10:27 AM | #18 |
829
Rep 3,982
I tried the vent filter to atmosphere. Not only was the odors bothersome during boost operation, but in my Vbox testing, I actually lost trap speed.
I have spent a bit of time inspecting my crankcase ventilation system, and found the factory system is pretty elaborate. There is a valve that controls where the crankcase vents to. During vacuum, decel, it goes straight to the intake manifold. During boost, idle, it goes to the rear air intake before the throttle body. The valve in the picture controls the diverting. I'm still trying to figure out a way to verify that boost from the manifold isn't leaking back into the crank case ventilation system. Unfortunately most of the system is not accessible as it is built into the valve cover gasket. FYI the system spin the oil away from the crankcase vapors by means of the centrifigual cyclones. Those little cone shaped devices in the the valve cover. The control valve is to the left of them.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
03-07-2010, 11:11 AM | #19 | |
Rep 1,432
03-07-2010, 11:16 AM | #20 |
Rep 1,432
This proves that having the vacuum at the crankcase helps the engine more than what is the octane benefit of the breather. So the best bet would be sustaining the vacuum and then in addition if possible, to avoid the oil and vapors in the intake.
03-07-2010, 12:00 PM | #21 | |
Rep 4,726
Holy thread bump...
Most of the benefits from having vacuum in the crankcase require building the engine from the ground up for that purpose. Otherwise you're talking about very small changes. Someone measure the vacuum at that CCV port on the intake.
03-07-2010, 09:50 PM | #22 | |
king of the hills
92
Rep 2,915
Moroso makes some parts to make this easy. http://moroso.com/catalog/categorydi...?CatCode=13023 |
