BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Turn off A/C when climbing a mountain?
      05-24-2017, 01:59 AM   #1
leoparker990
United Arab Emirates
13
Drives: Audi S4
There is a sign that when climbing a mountain turn off the a/c since it can overheat your car. Is this true or this would happened only to old/classic cars?
      05-24-2017, 02:14 AM   #2
stooker
F80 n00b
stooker's Avatar
Drives: '18 F80 / '06 S2K
I think most modern cars in good working condition will do fine at normal operating speeds and load. I do see you are in the UAE, so if outdoor temps are in the 40 Celsius range, it might not be a bad idea though...
      05-24-2017, 02:56 AM   #3
a90
Netherlands
66
Drives: F10 M5, E88 125, E70 X5, R1150
Our cars (M) are way overpowered for normal street usage, the amount of power needed for the airconditioning is about 10hp max on a hot day.
From that perspective, a stock M5 will have 550hp 'left' on a hot day for driving through the mountains. Seems enough and should not lead to problems.
If you have an older car with old technology airconditioning (less efficient, uses more hp) it might lead to issues when you only have 100 / 120hp or so. In that case, yes take that into consideration on a hot day in the mountains.
BMW E88 125 - 2008
BMW F10 M5 - 2016
BMW E70 X5 3.0d - 2007
BMW R1150r Rockster - 2003
Mercedes LP2223 - 1970 (http://www.lp2223.com)
      05-24-2017, 03:18 PM   #4
aerostar
Drives: 2018 F80
Not really about engine efficiency but heat soak, probably.
      05-24-2017, 09:52 PM   #5
jmg
jmg's Avatar
19943
Drives: G87 M2
Keep in mind that the M3/4 has good amount of cooling for track conditions that is more than adequate for what you are describing.
Oops, thought I was in the M3 forum. Your S4 should be fine, just keep an eye on that temp since you are in the UA.
2025 G87 ///M2 LCI - Stock
Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3
      05-24-2017, 10:46 PM   #6
Fundguy1
Fundguy1's Avatar
2050
Drives: 335 e93
It won't matter. You arent driving a poorly cooled monster motor muscle car or woefully underpowered 70s boat.
      05-25-2017, 06:46 PM   #7
Fast4d
Drives: 325
I remember doing that in an OLD seventies era toyota a few decades ago....
making probably 80hp. LOL.
      05-26-2017, 02:23 PM   #8
angelr
Drives: 07 aw/ir m coupe, 2013 S4
I make a mountain climb every day that says "turn off ac for next 14 miles to avoid overheating"
As said, no issue if the car is modern and well maintained.
      05-27-2017, 10:51 AM   #9
JoosyJoos
JoosyJoos's Avatar
Drives: 2011 335d
2008 BMW 335i  [0.00]
Your AC turns-off under heavy loads (WOT) anyway. It might be an issue if you were in an original 2002 BMW but not anything in the past three decades.
1997 M3 Coupe - BMWCCA I-Prepared #22
2006 M Roadster - 23,000 miles and slowly counting
      05-31-2017, 03:32 AM   #10
leoparker990
13
Drives: Audi S4
Yes, you are right, if your car is well maintained even it doesn't matter while your car is too old. It totally depends upon What condition of your car is? well maintained or not? And you are right dude, modern cars have no issue like that. thanks a lot
      05-31-2017, 06:59 AM   #11
GOLFFRR
GOLFFRR's Avatar
11278
Drives: GOLFFRR cart
driving a BMW no, anything else you may want to play it safe and follow the signs recommendations
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      06-05-2017, 06:38 PM   #12
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Just like low speed limits...this is mostly for older cars that were less efficient. Modern systems nowadays have better clutches that'll disconnect as needed and run a different refrigerant. I just rounded over 100k in my '10 X5M and topped of my A.C. after noticing it wasn't as cold as I'd prefer in CA's 90*+ temps vs WA's 60* averages...$34 later and it's ice cold
      06-05-2017, 07:22 PM   #13
Dackelone
European Editor
Dackelone's Avatar
Germany
10871
Drives: N54 e82
Normally I'd say leave the AC on. But... the OP lives in United Arab Emirates - so What is a HOT day? 40'C ? 50'C ???
I guess... I'd keep an eye on the oil temps... and IF you see more than 165'C oil temp... maybe turn off the AC.
Btw... during our summer Alpine drive's... I've never had a problem climbing the Alpine passes with the AC on.
Dack
Dack
      06-07-2017, 04:13 AM   #14
leoparker990
13
Drives: Audi S4
Yes, small 4-cylinder engine with an old, inefficient compressor, A/C might hurt performance, but in any modern car they have a good systems. But switching off the a/c reduces the extra load on the engine to run the a/c compressor.
Dackelone10871.00
      06-07-2017, 12:54 PM   #15
bd307
Chef
bd307's Avatar
925
Drives: Things with wheels or no wheel
Don't quote me on this, but I remember hearing a suggestion to turn the heater on in older cars during hill climb to keep it from heat soaking and on track to help cool off the systems.
Anyone has knowledge on this?
      06-07-2017, 01:25 PM   #16
Z K
Z K's Avatar
1915
Drives: G20 M340i, S15 Silvia Spec R
Turning on the heater helps cool the engine - you're venting the heat from the engine. It does actually work.
I've done this to keep my car from overheating on my engine swapped and turbocharged Nissan back in the 1990s which had various problems... the things I was willing to put up with to add horsepower back then... lol
But on a modern car, it is not necessary if your car is well maintained.
Auto Detailing Enthusiast!
Dackelone10871.00
      06-07-2017, 01:32 PM   #17
MightyMouseTech
MightyMouseTech's Avatar
4365
Drives: 13 135i 6MT LeMans Blue MSport
I do this on track. Turn the heat on low, just out the dash vents, and aim them out the window.
Dackelone10871.00
