Blown rear turbo? No smoke
06-20-2017, 05:04 PM | #1 |
Rep 185
My 335i has no boost 1psi on the jb4. I replaced the outlets because I thought there was a hole. Not the problem. Replaced the dvs, charge pipe o ring, and replaced all the vacuum lines and Boost solenoids.Took the intercooler off and back on multiple times. I checked the front turbo for shaft play and it feels like a brand new turbo. The rear inlet seem's to not be on 100% all the way but it's on there so I don't think that would cause no boost. Car sounds like a siren. Would one turbo being out cause no boost.
06-20-2017, 07:02 PM | #2 |
Rep 19
I had a similiar situation. Turbo siren, no boost, no smoke.
Ended up being a blown rear turbo. Next step is when the seals completely let go and you snoke out the streets. If you want to be certain remove the rear downpipe and check for oil. |
06-20-2017, 10:19 PM | #3 |
Yeah it's got a welded diff
40
Rep 56
Drives: '07 e92 FBO, JB4+BEF, E85+Meth
Try removing the JB4 and see if it helps. This just happened to me with mine and now I have to hunt down some harness gremlins in it.
