06-23-2017, 02:05 PM | #1 |
Rep 2
F30 xDrive - lowering springs suggestions (pic request)
Hi,
I've recently bought an F30 320d M Sport. It's an xDrive, so the OEM ride height, in my humble opinion, is far too high. I want to lower it circa 25-30mm. Are there any suggestions on lowering springs, with before and after pictures of F30 xDrives that have been lowered on springs (not coilovers)? Thanks in advance. Ste |
06-23-2017, 03:28 PM | #2 | |
Rep 182
06-23-2017, 03:56 PM | #3 |
Rep 2
06-23-2017, 06:26 PM | #4 |
No 55mph
1623
Rep 8,479
Scheidmann sells the AC Shnitzer lowering springs for ix, they have the same specs as the Dinan springs and they are in Europe
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-23-2017, 06:37 PM | #5 | |
Rep 182
12-28-2017, 01:00 PM | #7 | |
Rep 34
12-28-2017, 01:06 PM | #8 | ||
Rep 182
Maybe 20% body roll if I was forced to put a number to it but the car was even bouncier over bumps and the road and what not as I'm sure the car was constantly hitting or riding on bump stops due to the stock struts and shocks. I know it's more expensive but if your main goal is ride quality/improvement and not just cosmetics I'd go coilovers and not waste your time with just springs with the F30 stock suspension platform. Been very happy with Bilstein B14 PSS, doesn't slam but much lower than springs and it's quite stiff without being obnoxious for daily driving. |
12-30-2017, 11:06 AM | #10 | ||
Rep 10,322
413Bimmer31.00 |
01-01-2018, 06:09 PM | #11 | |
Rep 1,805
Do you have DHP? Start with Dinan springs/bumpstops and re-evaluate (30% stiffer / 20mm drop) If no DHP - go what guys above said
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
01-01-2018, 07:52 PM | #12 |
Rep 971
Drives: 2016 F36 435x MSport
Would DHP be the adaptive suspension? I too was wondering the same about springs. But I wasn't able to find Dinan springs for an XDrive.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
01-01-2018, 10:28 PM | #13 | |
Rep 1,805
yes https://www.dinancars.com/product/d1...0-335i-xdrive/ I now see you have a 435... just call dinan see if they have them
01-12-2018, 10:55 PM | #14 |
Rep 172
01-13-2018, 08:47 AM | #15 | |
Rep 191
"I still love the suspension,although I did notice that on an extreme cold days (-15c),the ride was supper jittery and stiff. Cold makes the fluid within the shocks more viscous,so thats understandable. If I had known this I would have gone with the b4s,cheaper and softer but also not as durable. Although the gripand handling is still amazing,glued to the road." You are in chicago - do you also notice this in the cold? |
01-13-2018, 10:29 PM | #16 |
Rep 172
Maybe on the coldest of days I notice a difference, nothing for me to complain about though. I don't find it super jittery. I do have a 328 vs his 335. . Maybe an influence of the weight difference? So better than the stock setup.
Tags |
f30, lowering spring, xdrive |
