Diagnostics help needed
06-29-2017, 07:05 PM | #1 |
Rep 222
Have a 2007 335i auto when driving with foot on accelerator when gear changes from 3rd to 4th get a hesitation as if car is seizing then jerks into 4th gear. If I driving and gradually build speed it's fine. I've tried reading codes but no codes show any ideas pls?
06-30-2017, 02:17 AM | #2 |
Rep 222
I've got a 134k on car services fully last month previously had a gearbox sleeve replaced with oil and transmission update then started experiencing above issue took it back to garage was told it's the mantrinics so had that replaced again oil was changed. Still issue continues have no idea what it is?
07-03-2017, 05:42 PM | #3 | |
Rep 111
07-03-2017, 07:31 PM | #4 | |
Rep 4,108
Have you tried M-S Manual upshift of M3-M4, M4-M5 and M5-M6? Does it shift properly when manually shifted at the same RPM and shift-point where the problem occurs in D? Check that closely, and let your shop know what you have found, and have them confirm it. Also, ANY kind of shift issue should be looked at by a transmission expert, with specific knowledge of your ZF 6-speed. Solenoids may need changing, or there may be other problems that if NOT corrected quickly can damage the transmission hardware to the point of requiring a rebuild. It's better to spend $200 to $300 in prevention as opposed to $3,000+ in replacement. George |
