07-03-2017, 01:32 AM | #1 |
Rep 3
Brake Pad Replacement Help
Recently bought Textar standard front/rear brake pads for my 218d sport (2014) as recommended by BMW.
I've never replaced brake pads before but have been looking to more jobs on the car by myself. Hence, does anyone have any helpful instructions/video guides for the replacement of the brake pads on my car (or similar)?
McKenzie
07-03-2017, 02:34 AM | #2 |
Rep 671
All single piston brakes are done pretty much the same way...
Here's a video on a 3 series brakes... Don't worry about the rotor replacement part.
'20 240ix convertible
07-04-2017, 06:26 PM | #3 | |
Rep 422
doccyber260.50 |
07-05-2017, 11:27 AM | #4 |
Rep 1,275
Several things to add to the vid:
1. Because the caliper piston will need to be compressed I always remove some of the brake fluid from the reservoir. Otherwise you can have brake fluid dripping out of the reservoir. Brake fluid is highly corrosive. It can remove paint! 2. When replacing pads I use a large flat screwdriver to compress the piston. Basically, I slide it into the opening at the top of the caliper, between the caliper and the outside surface of the rotor. I pull the screwdriver's handle out from the car, compressing the piston. This does not damage the rotor as it's much harder than any screwdriver! 3. Anti-seize compound is your friend. I put a very small dab on to the threads of the : a. large bolts holding the caliper bracket onto the kingpin b. rotor retention screw c. hub plate onto which the rotor sits d. hub ring onto which the wheel sits. |
07-05-2017, 01:01 PM | #5 | |
Rep 671
If no fluid has been added, if brakes on both axles are done at once, the fluid should be at the full mark when finished.
