Mystery Misfire
07-15-2017, 11:22 PM | #1 |
Rep 95
Mystery Misfire
New Plugs, Coils, Swapped Injectors around (All Index 12) New Valve Cover and Gasket, Cleaned Throttle Body, Walnut Blasted, New HPFP, all in the last 4 weeks trying to eliminate this misfire. Compression test 170-175 all around. Consistent combustion misfire cylinder 1. Could it be O2s? I have an MSD81 DME so don't think mosfets are an issue. Someone please help so I can install this turbo kit I don't want to keep throwing money if it's gonna keep misfiring. I got a single turbo kit coming soon but not gonna install it unless its fixed
07-15-2017, 11:34 PM | #2 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
Why not just check the mosfets? Easy enough compared to all the work you are doing.
07-16-2017, 12:45 AM | #3 |
Rep 95
07-16-2017, 04:15 AM | #4 |
Rep 95
Keep in mind I am good at sourcing parts and do all the work myself and already had a walnut blaster so everything cost me under $300 it's not like I'm throwing money. I had no misfire decided to change my rock auto coils/bosch plugs to ngk 95770 gapped at .18/delphi coils and changed valve cover and then all of a sudden misfire changed to a new valve cover have swapped everything from 1 multiple times and sticks to 1 good compression logs show o2s perhaps someone let me know what they see
http://datazap.me/u/tomhondros/misfi...-20&mark=34-48 |
07-18-2017, 09:29 AM | #5 |
Rep 17
I am pretty much going through the same problem. My car has cylinder 3 and 4 misfires under load and high RPM that I am currently trying to resolve. So far I have done:
Coils Plugs Index 12 Injectors Valve cover and gasket Next step is walnut blasting I am also swapping out the Vanos solenoids. Not sure were to go from here. Last edited by robertwhamm; 07-18-2017 at 12:07 PM.. |
07-18-2017, 09:39 AM | #6 |
Rep 906
I am not familiar with the idea that MSD81 DME has no MOSFET problems.
I am pretty sure my 2008 535 has the MSD81 and I had a bad MOSFET so I replaced all 6. |
07-18-2017, 10:49 AM | #8 |
Rep 906
07-18-2017, 11:38 AM | #9 | |
Rep 17
This is the part I found on a different post but not sure if its the same part for the MSD81 since the thread was about the MSD80's. https://www.digikey.com/product-deta...MCT-ND/1566830 |
07-18-2017, 11:48 AM | #10 | |
Rep 906
07-18-2017, 02:26 PM | #12 |
Rep 95
Getting mosfets tested today. Next thing is O2 sensors I'm running lean not sure why
07-19-2017, 12:04 PM | #14 |
Rep 95
07-22-2017, 06:23 PM | #17 | |
Rep 95
07-25-2017, 04:52 AM | #19 |
Rep 95
