07-19-2017, 07:35 AM | #1 |
Cheapskate
4464
Rep 4,995
Coilovers with Front Lift Systems
I'm still waiting to receive my 440i so I am buying some parts to install ahead of time. I want coilovers to lower the car, but my driveway is very steep and won't let me lower the car to my liking.
I'm looking into coilovers with front lift systems and found Fortune Auto has an option, but it's very expensive. Has anyone used them before? Are there any other options available for the f30/f32? Or a kit you can piece together for cheaper? And I'm not interested in bags. I drove in a car with them and didn't like the ride or opportunity for more maintenance issues. I'm specifically looking for a coilover with a front lift system. Fortune Auto Kit for reference: https://www.vividracing.com/catalog/-p-151576382.html Details on KW HLS, still need to find pricing: http://www.kwsuspensions.com/hls |
07-19-2017, 07:59 PM | #2 |
A family of bimmers
2757
Rep 7,743
thats pretty cool but i dont think you can drive on it aired up. i think its just for slow crawling over stuff
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
07-20-2017, 07:18 AM | #4 | ||
Cheapskate
4464
Rep 4,995
http://f30.bimmerpost.com/forums/sho...9#post21746699 |
07-20-2017, 11:37 AM | #5 |
Rep 733
Regarding the KW HLS I am also interested.
I asked directly to KW Germany and was told that it was not possible on F3X models. I did not quite understand why. It seems that it is necessary that in the threaded portion there are at least 60mm of space for the spring to work correctly. There was a fellow in the forum who installed it F555 http://f30.bimmerpost.com/forums/sho...=876888&page=4 I don't know if he had any problems, but he changed the springs of the HLS kit for others also of KW but with higher spring rate… I told KW, and they told me that they did not approve of that combo. I also sent a private to F555, but it seems that it is no longer active and never responded I will resume the subject soon and make a final decision. If you get any info to the subject, I would greatly appreciate you to publish it here
BCforged HB29 - M4 trunk - Bilstein B12 Sportline Damptronic - 435i type exhaust cf Cyba tips - M4 grills - 3D design cf diffuser - Kerscher cf lip |
07-20-2017, 12:36 PM | #6 |
Cheapskate
4464
Rep 4,995
The main issue with the KW ones is price. It looks like it's even more expensive than the Fortune Auto Version. It also looks slower than he other piston ones, and gives you less lift. Probably not the best option of the bunch.
ISC sells a modular kit, but I'm not sure if it'll fit other coilovers or not. if it's true that all of these coilovers are basically the same (Megan Racing, BC Racing, ISC, KSport, etc) just different colors, than it may work with more options. https://www.maperformance.com/produc...0mm-8k-10k-12k |
07-28-2017, 06:38 AM | #7 |
Rep 1,782
Can always go with a standard coilovers system and get aircups. They fit on the top of the springs and raise and lower the car with either s button or an app probably in this day and age. Not super expensive either.
https://www.stanceparts.com
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
07-28-2017, 09:31 AM | #8 |
Cheapskate
4464
Rep 4,995
yep, saw those too. thanks for posting the link. i they fit on a lot of different ones.
