07-24-2017, 03:04 PM | #1 |
BMW obsessed
9599
Rep 10,891
IND | Painted Front Reflector Install Guide
Painted reflectors are among the first additions made by any owner of a modern BMW. The unsightly orange reflectors installed in cars bound for North America instantly break the smooth lines of BMW bumpers.
IND provides painted reflectors as a cost effective solution relative to the purchase of a OEM European bumper. We start the process using the OE BMW reflectors for a factory fit, and the same paint process we would use to spray an entire car. Each reflector is sanded, prepped for paint, primed, then painted. We ensure that all lettering on the face of the reflector is completely removed providing the same finish as your factory bumper. Many enthusiasts enjoy installing their own painted reflectors, so we’ve created this installation DIY to help. Tools needed: • 8mm socket and ratchet • Adhesive remover or cleaning solvent • Nylon prybar (optional) Step 1: First, turn the steering wheel to full lock, in any direction. This will expose the fender liner. Step 2: With the fender liner exposed, begin removing the 8mm screw closest to the ground near the reflector. Step 3: Once the fender liner screw is removed you will have full access to the back of the bumper cover. Using your hands or a nylon prybar pull the edge of the reflector from the bumper cover. This may take some work to remove, but the leverage applied by a nylon prybar makes the job much easier. Step 4: After the reflector is removed from the bumper cover take a cloth and some adhesive remover or solvent and remove the excess adhesive. Step 5: Now that the surface is clean remove the adhesive cover on the painted reflector and push reflector in place. Make sure to apply even pressure around all edges. Step 6: With the reflector installed it is time to put everything back together. Place the fender liner back into position and secure it to the bumper with the 8mm screw. We've depicted the procedure in the images below. The images mirror the order of the steps above.
07-26-2017, 01:27 PM | #2 |
Rep 123
Thanks for the DIY! I've had these sitting in my room for the longest.
IND-Distribution9599.00 |
06-26-2018, 07:35 PM | #3 |
Rep 100
thanks for the DIY. just did this. the only thing i did in addition was i had a razor blade on hand which helped separate that really strong adhesive from the car.
06-27-2018, 09:54 AM | #4 |
BMW obsessed
9599
Rep 10,891
Nice! Yeah that is easily the most cumbersome part of the DIY, especially if there's lots that didn't come out with the reflector after extraction, haha.
06-27-2018, 03:03 PM | #5 |
Rep 18,747
Another pointer. Don't wait to long for this mod if possible, the old double sided tape getting harder to remove.
It will break in small pieces.
11-20-2018, 05:56 PM | #6 |
Rep 607
I just replaced my front and rear reflectors with IND paint matched reflectors. Easy install, very clean look. Thanks IND!
Life is short...Drive fast
IND-Distribution9599.00 BigMofoFrog181.50 |
11-21-2018, 06:04 PM | #7 |
Rep 892
Drives: 2019 M550i
When are you getting mediterranean blue for the center grill/front camera part?
11-24-2018, 10:58 AM | #8 | |
BMW obsessed
9599
Rep 10,891
https://ind-distribution.com/product?sku=IND-G30-CTRIM
11-25-2018, 12:25 AM | #9 | |
Rep 303
11-25-2018, 12:49 PM | #10 | |
BMW obsessed
9599
Rep 10,891
It is now listed on the website.
12-16-2018, 09:37 PM | #11 |
Rep 211
Drives: 2019 M550i; sold 2003 330Ci
Will you be posting a DIY for swapping in a painted center grille/front camera part? Interested in replacing this as well as the reflectors. Thanks
r33_RGSport13036.50 |
12-16-2018, 10:22 PM | #12 | |
Rep 303
Bymep132.00 r33_RGSport13036.50 |
01-17-2019, 11:16 AM | #14 |
Rep 18,747
Your car is 2019, the original double sided tape will remove very easy.
But if you insist, use GooGone then wipe it down again with rubbing alcohol.
MXNSITH198.50 |
01-17-2019, 11:55 AM | #15 |
Rep 61
Do you offer a rear tow book cover in matte black. I ordered my car with the m performance diffuser and they just slapped the gray cover that the car came with from the factory.
01-17-2019, 09:40 PM | #16 |
Rep 156
Tell the dealer to get the matching cover. If he/she doesn't get it done speak to his GSM. There is no reason they shouldn't provide it. That was a b.s move on their part..
01-18-2019, 08:17 AM | #17 | |
Rep 18,747
And I believe it came in grey primer, not matte black.
01-18-2019, 12:29 PM | #18 | ||
Rep 61
01-18-2019, 12:54 PM | #19 | |
Rep 18,747
Rattle can in Matte Black should fix it. It is small enough, wouldn't be hard to paint.
01-18-2019, 12:56 PM | #20 | |
Rep 61
01-18-2019, 01:09 PM | #21 |
Rep 18,747
