07-27-2017, 11:15 AM | #1 |
Rep 410
M235 stock AWD dyno results?
I've been trying to search through the forums for an answer of what a stock AWD m235 puts to the wheels, does anybody know? I have an AWD m235 myself and yet to dyno it, just wondering what they make to the wheels. Thanks
07-27-2017, 11:22 AM | #2 |
Rep 1,931
depends on dyno, fuel, air temp etc... but right around 285 on a dynojet, with 93, std with smoothing 5.
RWD is right at the 300 mark with 93. A m2 is 325 with 93.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
07-27-2017, 12:02 PM | #3 |
Rep 1,184
07-27-2017, 12:53 PM | #4 |
Rep 1,931
do the math...
What is the percentage increase/decrease from 320 to 300 6.25% for rwd and roughly 11% loss for awd best case. I have seen up to 18% loss for awd in some cases. Again all depends on the variables. It's usually 10-12% for rwd and 15-18% for awd. When you add in a cold day vs hot and humid and different octanes if skews the numbers.
www.nybmwcca.org
07-27-2017, 02:10 PM | #5 |
Rep 410
07-27-2017, 05:36 PM | #6 |
Rep 5,393
Keep in mind these cars are underrated significantly. The N55 in the M235 is making more like 360hp/370tq vs the 320hp/330tq paper rating.
07-27-2017, 07:49 PM | #7 |
Rep 598
07-27-2017, 08:05 PM | #8 |
Rep 2,010
Dyno HP chart
For what it's worth:
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
07-28-2017, 10:56 AM | #9 |
Rep 381
That's not a WHP number is it? Is Dinan extrapolating HP at the crank?
Current: 2019 640i GT, 2019 MX-5 GT-S, 2015 X1 xDrive35i
Gone, but not forgotten: 2017 m240i, 2016 GTI PP, 2013 Camaro SS, 2009 G8 GXP, 2008 G8 GT, 2007 335i, 2003 530i |
07-28-2017, 11:57 AM | #11 |
Rep 671
I wanna see dyno numbers for another brand of vehicle done on the same dyno, on the same day to see how that car's numbers compare to what their manufacture advertises.
I say that because everyone says BMW ... these days European brand ... always underrates their power. I also only see before and after mod dyno numbers for the same vehicle. Which is good because it gives a reference point on how the mod did. But what it doesn't show is how accurate the dyno might be. For all we know, that dyno might be inflating power number by 10, 20%... So every time it makes people think ... whatever brand of car they test on it ... that their power numbers are underrated by the manufacture. I guess I'm saying it's hard to believe that the 235, on that dyno, on that day, was producing more whp (340), than what BMW says is bhp. I could see whp match bhp because I figure a drivetrain loss of around 10%, but bmw underrating by about 10%, but to have a higher whp number? I find it hard to believe in this day and age... But then again .... maybe it's like tow ratings were on trucks where manufactures basically made up number until a few years ago...
'20 240ix convertible
07-28-2017, 12:25 PM | #12 | |
Rep 2,010
Other supporting points include several, supposedly reputable, automotive magazines who were consistently seeing somewhere around 4.4 seconds 0 to 60 times; better than the factory claimed 4.8 seconds. All of the above tends to support the notion that the N55 does indeed produce a bit more power than advertised. The stock power curve of 340 HP (at the crank) on the Dinan chart seems to support the better than expected track numbers. The ^20 HP and ^6 ft. lb. increases above factory are not huge, but very satisfying to know. And as I mentioned, the track performance seems to prove it.
07-28-2017, 12:33 PM | #13 |
Rep 1,931
your posting crank numbers, not wheel.
my numbers are verified.
www.nybmwcca.org
07-28-2017, 12:35 PM | #14 | |
Rep 1,931
Wrong. If that was the case, FBO with a tune people would be dynoing 450hp+.
www.nybmwcca.org
07-28-2017, 01:07 PM | #15 |
Rep 2,010
Uh, I don't think so. Dinan says they're seeing 340 HP and 336 lb. ft. at the crank, up slightly from the factory numbers. That 360 number is more like the M2.
07-28-2017, 02:54 PM | #16 | |
Rep 5,393
SO, based on everything I've research, read, and seen since following the M235 in 2014, the M235 6MT will typically put down around 305-310whp and 320-325wtq stock on the Dynojet. There are many printouts of these dynos on the internet. Most gearheads consider a 15% drivetrain loss for a RWD manual. So simple math shows 305/.85= 359hp at the flywheel and 320/.85 = 376tq at the flywheel. So yes, BMW has underrated this motor significantly. It also explains why turbo BMWs tend to be quite a bit quicker than their paper rating suggest. Mags have tested the 3,450lb M235 6MT to consistently run 13.3-13.4@106-107mph and these runs are on cars that had less than 2,000 miles. With some mileage, the cars would have certainly been even quicker and faster. The 1999-2002 Camaro Z28/SS was rated at 305hp/340tq however that car actually made around 305whp/330wtq at the wheels. So, basically the same power as the M235. Guess what, those F-Body cars weighed incredibly close to an M235 and pulled off eerily similar 1/4 mile ETs and MPHs. The M2 is the same way. That car consistently shows 335whp/360wtq stock on the Dynojet. So it's actually making around 395hp/420tq. The 3,400lb 6MT M2 consistently tests in the 12.7@113mph range. It basically runs the same 1/4 mile ET and MPH as 435hp/400tq Mustang GT (current gen) that weighs a couple hundred pounds more. A typical FBO M235 will see around ~360-370whp and ~390-400wtq. So yeah, it's about 425hp/465tq. It's not shocking seeing that those cars can run deep deep 12s at 115+mph. |
07-28-2017, 02:55 PM | #17 |
Rep 5,393
07-28-2017, 03:05 PM | #18 |
Rep 1,931
Only marketing ppl talk about crank hp which this thread is not.
We are talking about wheel hp. That being said, why are you arguing and bringing up crank numbers?
www.nybmwcca.org
07-28-2017, 03:47 PM | #19 | |
Rep 5,393
I fully understand the correlation between crank number and wheel power numbers. I'm a numbers guy through and through and spent more time (and money) racing at the strip and on dynos with prior cars than I care to admit. It began back in the mid-1990s for me I've provided my experience with Dynojets and other dynos, wheel power numbers, and how correlates to crank numbers and 1/4 mile numbers to provide clarity to the discussion. You can take it or leave it. |
07-28-2017, 07:26 PM | #20 | |
Rep 2,010
On the other hand, and as I mentioned previously, the numbers that stock M235i's lay down at the track tend to support the 340HP at the crank number for the weight of the car. Frankly, I'm not too interested in all of the claimed, tested or theoretical HP. I believe it's the timed 0 to 60 and 1/4 mile times that tell the final story.
07-28-2017, 09:24 PM | #22 |
Rep 2,010
Ha! At the end of the day, what really matters is who wins the race, whether it be 0 to 60 or the 1/4 mile. THAT is what counts. Right? Folks can play with HP or torque numbers all day, but... go to the track and read the numbers.
