Went shopping!
08-01-2017, 11:06 PM | #1 |
Rep 167
Went shopping!
So RB classics got sent off to be rebuilt after 6 years of service to the next step of RB next gens. Since most of the engine and the underside of the vehicle is accessible I decided to splurge and do extensive upgrades/long term maintenance. Have I missed anything that you would do while having the motor torn apart?
RB turbo service and upgrade Silicone inlets High Flow Oil drains Install kit PCV upgrade PCV screw cap OEM vent hose ADE motor mounts Replacement steering line rubber mount Front O2 sensors Black UUC transmission mounts Shiftek SS and DSSR BMS OCC On the fence about outlets. Is there a coolant I should use? Thermostat? Boost solenoids? Oil??? Any tips for assembly? Lastly, she still has a PROcede in her....I know nothing about tuning. I know how to do logs but other than that clueless. Thanks guys! I'm crazy excited about getting her back up and running. |
08-02-2017, 08:43 AM | #2 |
Old Man
248
Rep 131
Drives: DGM 335xi
Do the outlets itll help those turbos breath youll love the sound of the turbo spool.
Waterpump/thermostat? Coolant wise just bmw coolant. Any ll01 approved i personally use motul 5w/40 8100 excess. I would also check the oil pan to see if there is any leaks and get that replace. As for the proceed, dump it get yourself mhd and custom tune. |
08-02-2017, 12:38 PM | #3 |
Rep 219
Replacing vacuum lines seems to be the hottest "DIY" this month (I'm Finally getting to it this week)
IMO, replacing the stock OEM cowl with the M3 cowl was one of my greatest investments.. almost all maintenance can now be done without having to remove the cowl since it's no longer in the way Also Don't forget about cleaning your vanos solenoids; they're really quick and easy |
08-02-2017, 01:13 PM | #4 |
Rep 1,264
Read my N54 turbo upgrade install process:
http://my1series.com/2017/07/14/bmw-...tage-3-turbos/ I replaced a lot of things while I was in there.
750whp 135i Build | Budget 335i Build | F80 M3 Build
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135 📷 Follow me on Instagram: instagram.com/jakespence 🏁 Shop BMW merchandise: bimmerstreet.com |
meekz36.50 |
08-03-2017, 01:02 PM | #5 |
Rep 167
Thanks guys!
Outlets I'll order tonight. Rec's on a mfr? Water pump is basically new. I'd imagine thermostat was replaced with it. Understood on the coolant. Oil, I use amsoil. Comparable to motul? No leaks off the oil pan. I might wait on the tuner setup. I have a lot of questions/ignorance on the subject and its compatibility with what I already have, like integrating the PWM meth system, getting custom tunes, how to data log off those systems, etc. I do know the Vishnu system is old technology, but if it will hold me over for a bit until I'm sure I'll have no issues with what I have it what I need to get, I will. Totally forgot about the vacuum lines. Will get those tonight. Also had seen the cowl and forgot, thanks for mentioning!! I'll order that. VANOS Solenoids. Got it. That will be good preventative. Oh man, didn't realize about the water pump bolts. Are there any other one time use screws/bolts I need to get? I ordered the turbo install and I know that come with new studs/bolts for the manifolds. Are vband clamps necessary? Thanks guys, sooooo helpful. Appreciated. |
08-04-2017, 09:07 AM | #6 | |
Maximus Decimus Meridius
1132
Rep 4,586
F30 335i Melbourne Red Metallic M-Sport Package |
suspenceful1031.50 |
08-07-2017, 10:07 PM | #10 | |
Old Man
248
Rep 131
Drives: DGM 335xi
Amsoil is one the best oils along Motul/Rotella T6/Redline just make sure you use a 5W unless you live somewhere its cold/snow and park outside I would go with 0W verociousmotorsports has great silicone vaccuum lines BMS has a cowl delete if you wanna save instead of the M3 cowl Walnut blast? Changed pully's and Belt? Since your upgrading your vacuum lines did you upgraded vacuum nipple on the throttle body? |
08-07-2017, 11:38 PM | #11 | |
Rep 167
Also, one of the biggest questions I have... what do I do about my Procede/PWM meth kit? I cant' find anything referencing integration of the PROcede with MHD and can't find if the JB4 will integrate with the PWM meth kit. any guidance here? |
08-08-2017, 09:07 PM | #12 | |
Old Man
248
Rep 131
Drives: DGM 335xi
http://www.e90post.com/forums/showth...ht=vacuum+line As for the Procede/PWM you either find a tuner that can tune it or go MHD/JB4 |
