08-02-2017, 08:35 PM | #1 |
Rep 7
HELP ! Dropped a torx screw in engine bay!
Dropped a torx screw stupidely while trying to re install my bumper after swapping my grilles. It fell towards the front of the engine bay between the hood latch and the front of the car on the left side when facing the vehicle. I tried locating the screw as it is really big with a washer on it, but I could not locate it. I drove my car around my parking lot but nothing has fallen loose. Will it be okay? Will it eventually fall out or should I be worried about this somehow damaging my engine? I used a telescopic light with a magnet head but I could not find it for the life of me someone please advise!
08-02-2017, 09:13 PM | #2 |
Rep 598
its totaled.
08-02-2017, 10:45 PM | #3 |
Rep 260
If you really want to get it back, lift up the car and drop the belly pan. Otherwise, let it be and just a replacement bolt from the dealership. The lost bolt will work itself out. Worst case scenario, it works itself out during a turn and you run over it causing a flat.
08-03-2017, 06:20 AM | #4 |
Rep 85
08-03-2017, 07:05 AM | #5 | |
Rep 314
Seriously though, if you have a magnet wand, try poking around in there and see if you can get it to catch. |
08-03-2017, 07:31 AM | #6 |
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
...and if it pierces the blinker fluid reservoir, the car's toast!
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-03-2017, 09:56 AM | #7 | |
Rep 2,942
That said, you need that bolt. I would stop looking for it and order a new one from your dealer. Then, to be prepared for the next time this happens (and it will), buy three things: - A telescopic wand with a rare earth magnet on the tip (basically looks like an old-school telescoping antenna) - A flexible, spring-loaded 'grabber' tool at least 18 inches in length (basically looks like a long wired shutter release for an SLR camera ... if you remember those, LOL) for fasteners that are not metal or made from a non-magnetic metal such as aluminum - A magnetic bowl strong enough to hold metal objects while upside down (or after inadvertently kicking it ... ) It's important to have the right tools for the job -- and if the job involves the removal of fasteners, these three tools are must-haves.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
08-03-2017, 12:48 PM | #8 |
Rep 2,010
Well, at least you didn't drop the Torx screw down a spark plug hole.
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
08-03-2017, 01:30 PM | #9 |
Rep 2,942
Right there with you! (IOW: Been there, done that!)
08-03-2017, 01:55 PM | #10 |
Rep 1,117
Drives: 2015 BMW M235i
I just lost one of those intake clips the other day in similar fashion. Can't find it for the life of me!
08-03-2017, 01:59 PM | #11 |
Rep 2,010
Ha! Not to mention the somewhat scary days of actual carburetors with those big holes facing upwards. Heh!
I never had the misfortune of dropping something into the bowels of an engine, but I did experience something similar with my second motorcycle; a brand new Honda 160. The dual carburetors each had a peculiar choke that hung down into the carb throat when activated. Each of those chokes had a small, spring-loaded circular flapper valve. Well, one of those little flapper valves came loose one day and went right in a cylinder. Man, what noise! I could feel the resistance at TDC when I slowly cranked the engine over with the kick starter. I pulled the cylinderhead (which involved removing the engine from the frame) only to find this little piece of very mangled metal. At that point, I had no idea where it came from, so I reassembled the engine, only to have the same problem occur a week later in the other cylinder. Finally, we discovered the missing parts from the chokes. After that, got the engine repaired, including new pistons, new rings and new carbs under factory warranty.
08-04-2017, 08:01 PM | #12 | |
Rep 393
^^This is great advice.. In previous models, I lost a couple of trim screws down to the floor pan and it took the better part of an afternoon to get them back. Other cars that I owned were not as sealed below as the BMW lines.. Now I'm equipped with multiple magnetic, long reach retrieval tools and a cheap flexible camera mount for a smartphone. (All available cheaply from Amazon), But the most important as mentioned above is a magnetic base bowl to hold any fasteners or small tools combined with a small voice in the back of your head constantly telling you, "Is setting that 10 mm socket down on the engine cover worth the rest of your afternoon to remove the bottom pan and re-install it correctly? My sub-conscious answer is now a resounding no. No biggie.. Just different, and honestly, a cleaner way to work under the hood. |
08-05-2017, 03:26 PM | #15 | |
Rep 5,538
On the serious note, dealer had to remove some parts in front in order to get it out...done it for free though |
08-07-2017, 04:02 AM | #17 | |
Rep 1,091
Those were the days, my Friends - I was 27 back then Piotr
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD |
08-07-2017, 07:54 AM | #18 |
Rep 2,882
Way back when I used to hang out with an engine builder, he would talk about all kinds of gnarly crap they would find floating around in the cylinders - spark plug electrodes or the first ring of threads, carb parts, and those little circlips from the throttle linkages were probably most 'popular'. One of his paperweights was a piston from a big block with a socket embedded in the crown (also had one w/ an intake valve that way) - he called it his '$1000 paperweight' and would note that there was a matching boat anchor.
