08-04-2017, 05:23 PM | #1 |
Rep 9,788
Is my car a lemon?
Took it in the first time for a steering wheel/column noise about a month ago, maybe longer. After 4-5 times the noise is still there. The last time they replaced the steering column itself. I brought it back today because of the noise and another rattling noise popped up. So this would be the 5th time I've brought it in.
At what point does it qualify as a lemon? |
08-04-2017, 05:40 PM | #3 |
Rep 555
Depends on the issue, and depends on state. For California at least, if it is just rattles or plastic noises, you wont be able to lemon that. It has to be a mechanical or safety issue typically.
I am guessing you have the same noise a lot of us have, which is the plastic around the steering column causes rattles/vibrations. To make sure, if you hear it, try pressing firmly on it to see if it stops. If that's the case I think tightening the trim, or felt tape should fix it.
08-04-2017, 06:44 PM | #4 | |
Rep 9,788
08-04-2017, 07:33 PM | #5 |
Rep 5,393
Is it plastic in the steering wheel rattling (like around the airbag) or it actual metallic knocking?
Leaning "akwardly" really doesn't make any sense because that would indicate a broken sway bar link or something major in suspension. That sort of issue is easily seen and would make a hell of a racket. Probably in your head. |
mankid247110.50 |
08-04-2017, 08:28 PM | #6 | |
Rep 5,262
With the car running but stopped turn the steering wheel briskly left to right. Do you hear/feel any knocking? |
bmwx5er359.50 |
08-04-2017, 08:29 PM | #7 |
Rep 350
You won't be able to claim lemon law. Rattling and noises are somewhat subjective as to how loud is too loud. I agree with what someone above said: if it's mechanical and/or safety then that's lemon law
08-04-2017, 08:44 PM | #8 | |||
Rep 9,788
When I corner right the left side feels off somehow. Before there was vibration and droning inside the cabin. They said it was the wrong software installed and corrected it. The droning went away and it doesn't vibrate anymore. However, if you picture the car riding on rails when cornering left, it feels a bit off rails when cornering right. I have driven on canyon roads pretty often for 15 years with various cars so I'm very in tune with what a car is supposed to feel like. I had an X1 and X1 loaners the last few times I went in for service and even those felt much better than my car. Something is definitely off on the left side. I just hope they'll be able to figure it out and fix it. Yeah, I think you guys might be right. It didn't have those issues until recently and the rattling just developed today. It's strange really. If it gets worse other problems may occur. I will definitely push for it when that happens. |
08-04-2017, 08:58 PM | #9 |
Rep 555
Are you sure you don't have a bent wheel or something? I am surprised they are just throwing steering racks at it without going further.
Take it in again, and make sure you tell them you don't want it back again if they don't properly test the fix this time. Maybe even try a different dealer. If they are actually replacing the steering column multiple times, you can actually fall within the lemon law for sure here. I think 3 or 4 times is the required amount of a failed repair on the same item. Steering is a pretty big safety concern as well as integral mechanical part. So I would look up people that have done lemon law returns before. And if need be contact BMW NA. I would look for examples of people that have gone through this. Take it in again, see what they come up with. If I were in your shoes, and there was a legitimate issue with steering as you say, I would definitely try and lemon the car if they cannot repair it.
08-04-2017, 09:02 PM | #10 |
Rep 555
http://www.dca.ca.gov/acp/pdf_files/englemn.pdf
This goes over the requirements for California Lemon law: Basically from my understanding, 2 attempts to repair a serious safety issue, or 4 or more attempts at any other issue, or if the vehicle has spent more than 30 days for repairs within any time for repairs. This applies to the vehicle through the entirety of its original manufacturers warranty.
08-04-2017, 09:09 PM | #11 | |
Rep 9,788
08-04-2017, 09:21 PM | #12 | |
Rep 5,262
only thing left are the tie rods, ball joint or the whole steering rack which also includes the rods and joints If you can lift one front wheel just a bit with a jack and try to briskly turn left to right and see if you still hear the noise... then lower the wheel and do the same with the other front wheel http://www.realoem.com/bmw/enUS/show...diagId=32_2076 http://www.realoem.com/bmw/enUS/show...diagId=32_2071 Last edited by pikcachu; 08-04-2017 at 09:26 PM.. |
08-11-2017, 11:01 AM | #13 |
Rep 9,788
Dealer called and said my car is ready to go (6th or 7th time in for service). Do I pick it up or leave it there until the case is settled?
BMWNA is rendering a decision soon. I have also opened a case with the state of CA for arbitration/buy back. |
08-11-2017, 01:33 PM | #14 |
Rep 702
Drives: 2016 M235i Convertible
I'd pick it up and drive it - good faith showing on your part should it come to arbitration. It's also the only way to know if the issue has been fixed or continues.
16 BMW M235i Alpine White Convertible / MT (Daily Driver)
16 Audi Q5 3.0T (Wife's Daily Driver) 66 Porsche 912 (Project) 17 GMC Canyon Denali Long Bed 4x4 (Tailgatin, Haulin & Towin) various 'one design' sailboats / stinky hockey gear |
08-11-2017, 02:16 PM | #15 |
Rep 9,788
08-11-2017, 02:47 PM | #16 |
Rep 555
If the noise comes back, then you pretty much have your case right there. One more unsuccessful attempt.
08-11-2017, 04:00 PM | #17 |
Rep 5,262
Do you know what they did this time to fix ?
08-11-2017, 04:24 PM | #18 | ||
Rep 9,788
08-11-2017, 05:37 PM | #19 |
Rep 9,788
Although I asked for it, I don't think the dealer opened a PUMA for the car. Does it matter whether one was opened or not? I really don't want to keep coming back and give them one opportunity after another to fix the issue.
08-11-2017, 09:06 PM | #20 |
Rep 9,788
So it took me almost 2 hrs (traffic) after work to go pick up the car. Got here (at dealer now), went on a drive with the SA because the foreman had left for the day and asked that I go on a drive with someone here to confirm. Before I left the dealership, I turned the steering wheel and the noise is still there. They said that they put in some felt tape for the 2 trim pieces that snap together and that solved the rattling noise. Now when turn the steering wheel I get a resistance. I can actually feel something inside that's making it a tiny bit harder to turn.
Edit: took car home. Awaiting BMWNA's decision before I push much further with legal actions. This is just ridiculous. |
08-11-2017, 10:02 PM | #21 | |
Rep 5,262
Do they even know where the noise is coming from? Did you ask them if it is the rack? |
08-11-2017, 10:31 PM | #22 | ||
Rep 9,788
At the end of the day they told me to take it home and wait for BMW's decision. |
