08-07-2017, 06:42 PM | #1 |
Rep 81
Drives: 2018 BMW 440i F32 Coupe 6MT
F32 Suspension for xDrive vs non-xDrive
Hi guys,
I've been digging through the forum for the last few hours but couldn't find a solid answer for this and most of the thread were few years old. So hopefully I can get a better understanding of the difference combine with newer knowledge. I got a 2018 440i F32 xDrive Coupe with MPPSK 1. Is it true that the xDrive suspension set higher than non-xDrive? 2. If so, by how much? 3. Are they different part or just the damper setting makes the height different? 4. If adaptive M suspension lower xDrive's height by 10mm, does it lower non-xDrive even more overall if non-xDrive was initially lower? Thanks for your time! |
08-09-2017, 08:55 PM | #2 | |
Rep 3,493
2. Not a huge amount, but around an inch or so? Makes the car look a bit more like an outback IMO. 3. see #1. Wheel travel is the same as the non-xdrive, they just have to have it start off higher. 4. It does not lower the suspension 10mm. It does nothing to the suspension height. Only on non-xdrive cars does adding adaptive lower the suspension. What you can do if you have adaptive is get ACS springs and shockware, that will lower the height, stiffen it up, increase the damping rates, and give you a bit tighter package, I also did dinan swayarms. If you don't have the adaptive, I'd recommend only getting lowering springs if you get new struts/dampers that can match the increased rate.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
08-12-2017, 10:14 PM | #3 | |
Rep 81
08-13-2017, 01:11 AM | #4 | |
Rep 3,493
And the H&R are very suspect IMO because 1 size does not fit all. 435s vs 428s vs x-drive vs not, these all have significantly different weights and weight distribution. If they are saying it's the same springs/same part no.s, then I can't really take them seriously. Last time I checked, this was the case. This is why I went with ACS, they seemed to be tuned to the exact model, different part numbers. Dinan seems to take a similar approach, making sure the springs are tuned to the exact model. H&R seems to be way too far on the side of looks and sacrificing performance/ride/reliability. A 1.5 drop means either constant bottoming or much stiffer springs, which require stiffer (more) damping. Nothing is free here.
1QuikWS61623.00 |
10-31-2017, 11:03 PM | #5 |
Rep 81
Do I still get to pick and choose the stiffness of the suspension after replacing just the spring? Do I lose the option completely if replace with coilover?
