08-10-2017, 01:51 AM | #1 |
Rep 40
Brake noise when backing up
I am really enjoying my 230i equipped with M Performance Brake.
However, whenever after I drive over 10 to 15km, trying to back up for park, grinding noise from brake annoys me. I never have heard the noise when I drive forward. You guys have any experience like this? |
08-10-2017, 06:58 PM | #5 |
Rep 671
My M-Sport brakes do it whenever the rotors are cold.. forward or reverse. It's not bad and I only hear it when I don't have the music on, and the windows are down.
'20 240ix convertible
08-10-2017, 09:51 PM | #6 |
Rep 27
Ha. Same here and thought it was only on mine. Does it most of the time only when backing up; ever since I picked it from the dealership. m235i. Never really bugged me but good to know it's a common thing.
08-11-2017, 12:43 AM | #7 | |
Rep 40
When it is cold, I never hear noise. After running like 15 to 20km -that means it is hot- I always hear the noise when I back up.. |
08-11-2017, 03:23 AM | #8 |
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
I may be far reaching but could there be dust stuck between the caliper and the disc that causes these sounds? When I was ordering my car my dealer advised me to not equip it with M Performance Brakes as these would cause this annoying noise and would only work when they are hot, that's why I went for the M Sport brakes as these are a nice compromise between the standard ones and the track focused ones.
08-11-2017, 10:28 PM | #9 |
Car Geek
3727
Rep 3,632
I would confirm the noise is from the disc brake pads vs the parking brake shoes due to corrosion between the shoes and rotor hat. Follow the procedure in the manual for cleaning off the parking brake shoes and see if the noise changes or disappears.
08-19-2017, 09:03 AM | #10 |
Car Enthusiast
282
Rep 501
This is a very common and Standard thing on any BMW car with performance brakes.
It is normal for the brakes to make noise from time to time as they are a performance brake and are made to perform very well.. But if you are very concerned about it... you can take it to your dealer and they will usually try chamfering the brake pads to help get rid of the noise...or put in a different brake pad.. The newer pads do not perform as well but they dont noise. Me personally.. a little brake noise never bothered me..if its constant squealing or grinding every second you touch the pedal..then you have an issue. PuMA measure F3x F2x Rear Brake Squeal CA 61266427-03 - 28/01/16 ui-button Complaint: Brake Squeal during cold or damp conditions from the rear brakes during initial brake applications after a cold soak Cause Composition of brake pad material in brake pads with part number 6 799 809 Measure Measure updated to F23: ------------------------------------------- Upon confirmation of an excessive brake squeal from the rear brakes and there is found to be no signs of binding, corrosion or excessive wear inspect the brake pads to confirm the part number installed. If part number 6 799 809 is found to be installed submit an "Info Only" Puma Case with reference to this Measure and replace the brake pads with part number 6 873 094. During the replacement, ensure that all steps for replacement, lubrication, and bead in procedures are followed as outlined in ISTA/D Validity information Model series:[F30, F32, F31, F23, F34, F22] Engine range:[ALL] Body style:[ALL] Fault codes:[] Production period:Up to 01/07/14
2016 M235 - Melbourne Red
2005 BMW M3 - Sold Licensed Automotive technician for BMW Regina |
bimmerfile621.50 |
08-21-2017, 06:03 AM | #11 |
Rep 1,220
Drives: 2015 M235ix
Thanks, Taunto, for a definitive response.
This topic comes up about every six months and engenders the same discussion. Given such a wonderfully informative answer, I vote that we put it to bed and BAN IT FROM THE FORUM FOREVER. I know, it's early in the morning. |
08-21-2017, 06:57 AM | #12 | |
Rep 2,067
2019 X2
08-21-2017, 03:51 PM | #13 |
Rep 1,220
Drives: 2015 M235ix
08-21-2017, 10:22 PM | #14 |
Rep 393
I agree with this and yet, the //M performance brakes went, "screeee...scereee...screeee....." as I backed out of the driveway this morning..
But again, I washed it yesterday afternoon after a, "spirited jaunt", so it rusts up immediately with the water and the PH change in the soap. All I can say is that it goes well with the leather smell and the exhaust in the morning as it warms up with the windows down.. You barely hear it.. |
08-22-2017, 03:28 PM | #15 |
Rep 518
Yeah, mine only does it backing up before warm up
Estoril Blue 6spd M235i LSD Sunroof delete AWE touring exhaust Fabspeed sport cat
