Car needs refresh; what needs to be done?
08-11-2017, 03:12 AM | #1 |
Rep 803
I'm in the process of restoring my whole car, it just hit 80k miles.
What all should be done by now besides walnut shell blasting? Trans, engine, etc Running stock
black/black/black e92 loaded
Instagram: _eamon_ |
08-11-2017, 08:55 AM | #2 |
Rep 53
that depends.
Although it it spread left and right and a litte search would do wonders, I try to remember and give you a short list. This might not necessary depending on your cars healt: - Trans fluid flush (do it at ZF, they built the trans and know what to do) - Oil filter housing gasket (becaus: it will leak sooner or later) - spark plugs - maybe ignition coils - all vacuum lines - check the boost lolenoids. If noisy->replace - with 80K miles, its time to think about everything that has to do with suspension (coils, and esp. all the control arms [at least their bushings] ) - Oil pan gasket (because: see oil filter housing) - PCV valve - maybe buy an oil catch can after nut blasting - while not tuned, also inspect charge pipe - they might leak even with stock boost, depending on your model year ......
Mods: MHD Stage I, xHP, VRSF 3" Chargepipe, Turbosmart DV, VRSF DCI, Golf Tee Mod
08-11-2017, 08:56 AM | #3 | |
Rep 112
I do hope you don't need a new engine and transmission at your mileage. |
08-11-2017, 09:06 AM | #4 |
Maximus Decimus Meridius
1132
Rep 4,586
If ain't broke, don't fix it.. I'd stick to the regular N54 maintenance schedule..
F30 335i Melbourne Red Metallic M-Sport Package |
Chris@VargasTurboTech1934.50 OlliD28.50 |
08-11-2017, 09:08 AM | #5 |
Rep 151
Also add motor mount, check ball joints and shocks/struts.
My ball joint are leaking at 54k and my brothers shocks were done at 80k. Do the motor mount anyway if you care about your motor. |
08-11-2017, 09:40 AM | #6 | |
Rep 1,735
|instagram@underground6t9| |
08-11-2017, 09:50 AM | #7 |
Rep 1,532
Yep, staying on top of maintenance is different than throwing parts at the car -but there are exceptions. I.e. if you're changing turbos at 90k and have a perfectly fine but original working water pump.... I would change it anyway. Just too easy once you're down there.
Things like silicone vacuum tube etc, after you own the car and changed it all to good stuff will be a once-every-now-and-then upon your own evaluation and inspection. I have pre-emptively done plugs/coils, and would do again in certain situations but I wouldn't randomly change out injectors for no good reason. Just too much money. Chris |
Underground6t9316.50 |
08-11-2017, 03:27 PM | #8 |
Rep 803
I think I've heard that the trans fluid should not be touched; is this incorrect information? I feel like the trans does not feel like it did 20K miles ago, like there's a hesitation. Slipping maybe? Should I just have the fluid flushed and replaced? Automatic.
Also for the posters who said to work on the suspension, I had also posted a thread in the correct subforum for advice on options. If you want to chime in it'll be here: http://www.e90post.com/forums/showthread.php?t=1411787 Can't wait for this upgrade
08-12-2017, 11:06 AM | #9 | |
Rep 1,070
Items that become problematic and that you should check would be (to name a few): Plugs Coils Vacuum lines Water pump/hoses if doing pump OFHG VC and/ VC gasket PCV Vanos solenoid cleaning Boost solenoids As others have mentioned, throwing parts at a car in good working order can be expensive and yield little benefit. One thing to consider if you are doing work is look at items in the path of your work and replacement of those items if they typically fail or wear out at mileage similar to yours. Then, you spend some extra money in parts, save on labor and you are LIKELY doing yourself a favor but even that's not guaranteed. You mentioned suspension. At 80k, you MAY benefit from shocks/struts/mounts, and potentially sway end links, control arm, ball joints and thrust bearings... have a suspension person check these and advise before pissing away $1500 in all new parts..
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
08-12-2017, 01:14 PM | #10 |
Rep 1,484
doing preventative maintence isnt a bad idea. It better to just replace the part when you want to then to have to do it when your on the side of the road.
I would say the priority would be water pump and themostat. There known to go out between 70-80k like a clockwork. Then i would say oil filter housing. The oil filter housing, i would say just replace when it actually starts leaking though. |
08-12-2017, 01:54 PM | #11 | |
Rep 1,070
Also, it is much better to replace KNOWN problem issues on your schedule rather than on the side of the road.
JWebb335xi
08-12-2017, 02:01 PM | #12 |
Rep 1,484
08-12-2017, 02:10 PM | #13 |
Rep 2
I'm thinking of purchasing a 2009 335xi with 95k kms.... a local toyota dealership has it listed for $15,500.... i've had some discussions with the used car sales manager, and we might be able to make a deal for around $13k....
He advised that the waste gate is rattling....i've read about the temp fixes for this....but want to know should i be prepared to spend $4k addtional in the near future to fix this? i s it worth it to buy knowing this? what about water pump, gaskets etc... any advise, insight to provide is appreciated... thanks. |
08-12-2017, 03:27 PM | #14 | |
Rep 1,070
The real question is whether the car is worth $18k to you knowing you may have other general maintenance and other repairs coming up. I have an 08 with just over $100k, and I'd replace turbos if they failed even though that may not make the best economic sense... I like the car and, therefore, may spend more than is reasonable to keep it running well.
JWebb335xi
08-14-2017, 01:17 AM | #15 | |
Rep 1,271
2007 335i Jet Black e92 6AT - VRSF Full street exhaust DP, Chargepipe 7.5 FMIC, MHD, XHP, Koni orange/Eibachs, some other stuff
2007 335i Jet Black e90 6MT - Eibachs, magnaflow exhaust, carbon hood, short shift kit, some other random stuff - being sold somewhere sometime soon probably 2010 335i AW e90 6 AT Msport - The GF took this one over... JB4, PE exhaust, Koni yellows/Eibachs, pink badges, fuzzy steering wheel cover ? |
08-14-2017, 10:19 AM | #16 | ||
Rep 1,070
On a similar note, BMW just replaced my HPFP at 99k miles and 9 years old. I believe our warranty on that issue in the US is 10 year or 120k miles. Either way, I didn't pay a dime, which allowed me to "feel good" about paying BMW techs to do a few other items I didn't want to do on jack stands!
JWebb335xi
08-15-2017, 06:43 PM | #17 |
Rep 3,736
This. Only proactive maintenance I would suggest is to replace your water pump and thermostat for piece of mind so you don't get stranded, normally goes out right around 80K miles.
BeastMode335i1132.00 |
