E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Flutter/Squelch after turbos inlets installed?
Reply
      08-12-2017, 07:53 PM   #1
335inDe
Drives: 07' 335i
After having Pure Stage 2 DD's and inlets installed I'm having this anomaly. While getting logs for tune revisions, when I let off the pedal abruptly after the pull I get a real nasty squelch sound. It also happens during gear changed when under a decent amount of boost. There is also a flutter sound under low psi occasionally when shifting gears. I checked all the boost lines, charge pipe, diverter valve hoses/lines etc. Any ideas?
Thx in advance!
Mods:
335is N54 DCT
Pure STAGE 2 DD's
DCI
Vrsf 7" fmic
DP's
charge pipe with forge diverter valves (yellow spring)
MMP inlets
Stage 2 fuel pump
3" full exhaust
      08-12-2017, 08:02 PM   #2
Chris@VargasTurboTech
Drives: All Things TurboCharged
Hard to hear what you're hearing through the words you wrote.
Make sure your bov spring is correct and that you have a dedicated and appropriate sized line going from your manifold to the bov directly.
That said, larger turbos and inlets make some more glorious noises than perhaps your used to.
Chris
      08-12-2017, 08:32 PM   #3
335inDe
Drives: 07' 335i
Thanks Chris that's a question I have been trying to figure out. I know with Tial people use a larger diameter vacuum line. How about Forge Diverter Valves? I cannot find a definitive answer. Thanks!
      08-12-2017, 09:21 PM   #4
cristy7610
Romania
37
Drives: BMW E92 335I
That sound is normal with inlets and Tial BOV.In my case I replaced the line to the intake with larger one..Fixed the noise of dying owl ,most of it
      08-14-2017, 09:55 AM   #5
It won't hurt to use a larger diameter, high quality line. Always recommended.
Thanks,
Chris
Reply
e90post
