4 Ohm & 2 Ohm Speakers - 1 Amp
08-12-2017, 08:51 PM | #1 |
Rep 98
Hi All,
Just after some advice before I purchase some new equipment. I was going down the route of installing a full Audison Voce set up which comprised of 4 x 6.5" woofers, 2 x 3" mids and 2 1" x Tweeters in my e93. However, to try and save on some costs, I'm thinking of utilising my Focal ES100K - ELITE K2 Power Series 4" component speakers and getting two sets of the Focal ES 165 KX2 6.5" woofers, Seeing that the ES100's are 4 Ohm and the ES165's are 2 Ohm. Would i have an issue running this off a single amp, such as the alpine pdx v9 or would i need to wire the ES165's in series to lower the Ohm's from 2 to 4. And by doing this would i damage the speakers ? Thanks all. |
08-12-2017, 09:09 PM | #2 |
Rep 4,121
You can expect that the 2 ohm speakers will be 3db louder on the same rated amp channels
Keep your 4". Perfect for e90 Dont use a 6.5. Get a proper 8 for under the seat |
08-12-2017, 09:17 PM | #3 | |
Rep 98
I've got 8" installed already, whilst the sound OK, having 2 6.5 installed in the doors should sound better right, given the location. |
08-12-2017, 11:00 PM | #4 |
Rep 13,134
So you are going to cut up your doors?
You might want to consider Jehnert doorboards. See there website. The Jehnerts are good speaker also. There 8 inch underseats are audiophile quality. Xe 200's Last edited by ctuna; 08-12-2017 at 11:08 PM.. |
08-13-2017, 06:20 AM | #5 | |
Rep 98
hence the need to want to use two 6.5" |
08-13-2017, 08:02 PM | #7 | |
Rep 4,121
The only time ive known the real pros to install 6.5s is when the are doing 4 of them in each side (jehnert dpor panel) on lieu of the 8 Edit. Just read your lower post. I still think thats overkill but have fun! 8/4/tweeter and you are done |
08-14-2017, 01:36 PM | #8 |
Rep 98
I've also got some A frame pillars for the tweeters and tweeter pods for the mids, that i could possibly install.
08-15-2017, 06:20 AM | #10 | |
Rep 98
I've currently got the tweeter pods in place which are housing the 1" focal tweeter. However the initial plan is to replace these with a custom pod which would house a 3" mid. The tweeters would then be moved into the A frame pillars. Regards |
