Is it possible to supercharge a n54?
08-17-2017, 09:37 AM | #2 |
Rep 152
08-17-2017, 09:40 AM | #3 |
Guest
Rep n/a
Drives:
Ellis Juan > supercharger
davidwarren188.00 |
08-17-2017, 06:25 PM | #7 |
BimmerPost Supporting Vendor
24498
Rep 191,502
08-17-2017, 07:44 PM | #9 |
Head Fry Cook at McBurgertown
507
Rep 1,005
Yes, you can have both.
It's called twincharging. You'd actually make more power (more area under the curve), but I don't think the N54 is an ideal candidate. These engines seem to not like a such a massive torque hit down low, which you'd certainly be signing up for with a twincharger set up. Perhaps on a built motor it would make a great drag race car.... Last edited by terryd5150; 08-17-2017 at 08:02 PM.. |
08-17-2017, 08:05 PM | #10 |
ahat
1046
Rep 2,592
From my perspective, only recently have they been able to closely integrate wastegate managed loads with elect throttle control. To add SC to that management is not quite an off the shelf option. Can it be done?, most certainly. The payoff? Likely minimal. All the options needed can be managed with low speed air velocity and progressive boost. If you need more power at say below 3000rpm, then you likely have more weight than an e9x and are in need of more displacement (or torque X), not just boost.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 Last edited by 335e92tx; 08-17-2017 at 08:12 PM.. |
08-17-2017, 09:37 PM | #11 |
Rep 691
You could, no different then converting a supercharged motor to turbocharged (e.g., twin turbo kits for the C7 Z06 LT4).
ALSO -- You realize that turbos are more efficient, have no parasitic loss, and have a more "controllable" powerband.
Results > Last edited by Mit_Boost; 08-18-2017 at 01:41 PM.. |
