08-17-2017, 08:36 PM | #1 |
Rep 303
M240i Dyno day
I wanna tell you that today i put my stock M240i in the Dynapack Dyno with just Dinan Midpipe and the results are quite amazing:
384whp 638wt (Nm) We dit it 3 times with the same results. Another case of BMW underrating ? PS: Premium 91 fuel. |
08-17-2017, 09:26 PM | #2 |
Rep 1,931
slips or it didn't happen.
seems awfully high, like as if its complete BS. Here is BMS's dyno, even with a jb4 its no where near your claim.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
08-17-2017, 09:50 PM | #3 |
Rep 1,372
I'm sure he meant 384 BHP. Is he not in the US? (torque listed as Newton Meters). European dynos always show BHP somehow.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
08-17-2017, 10:15 PM | #4 |
Rep 1,931
384 Brake horsepower [bhp]
= 389.325 951 522 8 Horsepower [HP]
www.nybmwcca.org
08-17-2017, 10:17 PM | #5 |
Rep 1,931
when have you ever seen 3 dyno runs produce the exact same numbers?
It doesn't happen like that.
www.nybmwcca.org
08-17-2017, 11:10 PM | #6 |
Rep 303
It's a Dynapack dyno. Direct conection to the rear axle. And the numbers are expresed in whp (wheels horsepower) and NM.
That graph you showed it's a 340. Same engine than M240i's but factory detuned. Tomorrow i'll upload the graphic. So it's not BS. |
08-17-2017, 11:11 PM | #7 |
Rep 303
08-18-2017, 04:04 AM | #8 |
Rep 50
Your dyno is wrong sadly.
380whp is about 450bhp at the fly. Even with a free flowing downpipe it isn't happening. My M140 UK car (Same as M240) on 99 octane fuel and decat downpipe made 380bhp 550nm at the flywheel. I even think this maybe a touch high but standard M1/240's here in the UK make around 350-360bhp bone stock. My car bone stock made 360bhp, again at the fly. |
08-18-2017, 07:47 AM | #10 |
Rep 913
Drives: '17 F22,15 E84 M Sport,02 R53
Truthfully - comparing different dynos of different cars on different days on different types of dynos - is meaningless - in different countries even more so.
08-18-2017, 08:46 AM | #11 |
Rep 1,931
its all about the gains vs. baseline. That being said, there is no way this car is making those numbers on 91 with just a midpipe. The correction factor on this dyno is set high.
www.nybmwcca.org
WolfGTI716.00 |
08-18-2017, 09:03 AM | #12 |
Rep 913
08-18-2017, 09:53 AM | #13 |
Rep 1,541
Dynapack reads pretty high generally. You're literally dynoing with the wheels off the car. Used one to tune my s2000.
Very consistent and safe dyno, but read pretty high compare to dyno jet.
08-18-2017, 08:17 PM | #16 | |
Rep 1,372
https://www.carthrottle.com/post/the...whp-explained/
DragonGate71.50 |
08-19-2017, 08:13 AM | #17 |
Rep 1,117
Drives: 2015 BMW M235i
Yep, believe these are crank measurements.
08-23-2017, 04:35 PM | #20 |
Joint Chiefs of Staff
24342
Rep 191,109
Is that wheel HP? 384?
08-26-2017, 02:39 PM | #21 |
Rep 5,385
Good Lord what's with the ignorance in here? The dyno used in this instance was a Dynapack which mounts directly to the hubs (i.e., wheels removed). Compared to the more common Dynojet, the Dynapack will typically show about 10-12% higher power numbers. There's no BS here.
CP911986.50 |
08-27-2017, 02:32 AM | #22 |
Rep 1,772
384 at the crank is more believable but even then the torque figure even at the crank is way off let alone at the wheel.
Take your car to the drag strip and if trap speed is 120mph or about then maybe. I very much doubt it. |
