JB4 settings for meth?
08-21-2017, 09:44 AM | #1 |
Rep 367
Can someone take a screen shot of their jb4 settings for meth and post for me? I just want to make sure mine are in line before i do my first run with it turned on.
Current setup: JB4 vrsf charge pipe with bov vrsf intercooler afe intake cat back exhaust bms meth kit (running 50/50 meth/water) Thanks for the input.
Vrsf fmic, vrsf charge pipe with bov, vrsf catless down pipes, afe intake, manzo exhaust, bms jb4, bms cowl filters, bms oil cooler valve, 19" Konig Oversteer wheels, wrapped up, hood vents, carbon fiber wing, custom headlights, air lift v2 airbag system
08-22-2017, 02:32 PM | #2 |
Rep 367
not one meth user can help out?
08-22-2017, 02:36 PM | #3 |
3442
Rep 79,211
JB4 setup:
Using your BMS DATA cable or JB4 Connect Kit you'll have to enter a few settings to enable the meth integration. Under the meth tab set Signal Scaling to 60. Then set Boost Additive to 40. The Boost Additive determines how aggressive the JB4 will be with boost when WMI is at full flow. We suggest the 40 setting for pump gas as a starting point. If you happen to run higher octane fuel such as race gas or E85 then this value can be increased. The maximum suggested setting for factory turbos is 75. Note the WMI maps are application specific so refer to the JB4 thread for your application for additional information. For the N54/N55/N20 the WMI map is map3 while with the S55/S63/B58 the WMI map is map8. WMI can be used on other maps with reduced safety WMI flow: Note when the system is operating normally you will see a WMI flow reading of 60% to 100%. It's normal for the flow reading to vary between 60-100% based on weather, fluid injected, nozzle size, etc. Readings below 60% indicate a flow issue. If you run out of meth the reading will drop to 10% or less. If you have a wiring or electrical issue the reading will drop to 0%. Priming system: The first time you install and any time you run the system dry you will need to prime the pump to get all of the air out of the pump and lines. If you see air bubbles in the line feeding the pump you will need to resolve that issue first and then prime to remove air from the pump after. Any time air is detected in the pump or lines leading in to the pump the JB4 will give a lower meth reading. Note it is normal to see air pockets in the short line between the solenoid and the nozzle when the system is off. It is also normal to see an occasional air bubble in the line feeding the pump. But many bubbles combined with a consistent low flow reading indicate air is leaking in to the system. N54 Purge Directions: Disconnect the line from the nozzle and place it in a water bottle or bucket to catch the fluid. Turn the ignition on and enter JB4 command mode. Go to option 7/5 (meth on oil temp) and while in command mode press the gas pedal to the floor to activate the pump and push the air out of the system. This generally takes 5-10 seconds and you can visually confirm the inlet and outlet lines are free of air bubbles. If you see air bubbles appearing in the line going towards the pump double check all fittings and lines to ensure they are tight. All others: Select the WMI map for the application. With ignition on and JB4 software connected press the small “purge” button in the upper right hand corner repeatedly to activate/test the pump. Each press will activate the pump for around a second and it should take 6-8 seconds to push all the air from the pump and get it properly primed. http://www.burgertuning.com/instruct...it_install.pdf |
DaFish157.50 |
08-22-2017, 05:46 PM | #4 |
Rep 367
thank you so much!
Jeff@TopGearSolutions3442.00 |
