09-01-2017, 02:30 AM | #1 |
Rep 28
Where to find M Performance Suspension Springs?
Hi guys, I recently bought the M Performance Suspension retrofit kit for my F30 328i Luxury line with standard suspension. I understand that on top of the retrofit kit, I will need to get the M Performance Springs (Red in color) and also the front and rear sway bars to complete the setup.
I've found the part numbers for the sway bars on RealOEM but could not find any info on the MP Springs. Does anyone here has info on where can I get a set of the MP springs? Thank you! |
09-02-2017, 11:31 PM | #4 | |
Rep 2,499
Message them and they?ll get back to you right away with all the proper hardware you need. The kit you bought should have come with the sways if you bought the right one though. That?s what I thought anyway. |
09-03-2017, 10:01 AM | #5 |
Rep 211
These are the part numbers for the 335i. Don't know if the 328i springs are different, probably are.
31 33 6 860 630 :B1-Front Coil Spring 33 53 6 860 621 :B1-Rear Coil Spring
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
raystinger6.50 |
