N54 N20 tmap sensor mess up
09-03-2017, 09:32 AM | #1 |
Rep 972
Hey
So working in the dark to swap my tmap sensor to 3.5bar one, i decided to switch the wires around in the plug rather than buy an adaptor. End result is I damaged the pins that go into the black plug that goes into the tmap sensor. I am trying to think of a solution fix this... I know the easiest think to do is to find a broken 35i and cut the wires from this but there aren't many about and I need to fix this ASAP. Another solution I wanted to check is buying the adapter, which I should have bought in first place, and cutting one end of that and soldering it to the oem wires... Anyone know if this will work? It's a major cock up and I do already feel really bad about this.. Thanks
2016 M140i
07 E90 335i: JB4, Trebila BEF, BMS DCI, VRSF DPs, Scoops, 19" CSL Reps, 5" ETS FMIC, VTT Inlets, BMS CP, HKS BOV, BMS Meth Injection - sold |
09-03-2017, 10:20 AM | #2 |
Rep 531
just go buy the pins and rewire... dont understand how you could mess up
06' Space Grey 335i FBO
MHD Stage 2+ e60 OTS|VRSF V2 Catless DPs|VRSF 7 Inch FMIC|VRSF Charger Pipes|Turbosmart Supersonic BOV|K&N DCI's|VRSF OEM Silicone Inlets|BMS OCC|FUEL IT STAGE 2|07+ TCU Conversion|XHP Flashtool Stage 3 Race Map|1m Front Bumper|CSL Wing|Aero Rear Bumper|DTM U Shaped LED Angel Eyes with RGB Demon Eyes|M3 Cowl |
09-03-2017, 10:44 AM | #4 |
Rep 531
crimp pins go to any electronic sorta store
