09-09-2017, 09:53 AM | #1 |
Rep 235
Coding options
Hi All,
New to the forum and my first post! I've just placed an order for a 520d se, and due to budget constraints I've had to limit the options I ticked and pick wisely. I've gone for the HK sound system, sports seats, shadow line exterior trim and additional 12v sockets. I've seen that there is the ability to code certain things on BMW's, does anyone know what 'options' are already fitted to the car, but just need activated through coding like CarPlay for example? My mate has an A4 and there are options on that which he has enabled through an app connected to an OBD adapter, is it the same kind of thing on BMW's? Any input will be greatly appreciated! |
09-09-2017, 03:24 PM | #3 |
Rep 8,364
Coding is generally not about skipping check boxes and adding later.
Carplay requires an FSC code or provisioning so it cannot simply be coded. |
09-09-2017, 05:50 PM | #4 |
Rep 2,073
Enhanced bluetooth might be the only option on the options list that can 'just' be coded IIRC.
Then carplay and maybe wifi hotspot may be added later with an FSC code as stated above. But as for 'hardware' options, BMW is not in the habit of putting in 'unused' hardware which can be activated by coding. Generally, if the car is missing an option you will need to retrofit hardware and THEN code it to get that feature. |
09-09-2017, 06:35 PM | #5 |
Rep 235
Thanks for the replies!
A couple of questions.. What's an FSC code? What does advanced Bluetooth give over standard? Is high beam assist codeable? What's needed to change/access these codes/modules? I'm not against paying for modules to enable functions (which I may well do once I actually get the car), just wondered if there's any freebies tucked away somewhere. |
09-09-2017, 11:35 PM | #6 | |
Rep 8,364
Enhanced bluetooth includes office functions. High beam assist is not without DA cameras, Adaptive LED's, and turn signal stalk button to enable. |
09-14-2017, 07:59 AM | #9 |
Rep 235
Another couple of coding questions..
I've seen a couple of apps for coding from bimmertech and Carly, anyone tried either and any preference? Also, is it possible to have a digital speedo coded on to the dash, rather than just in sport? |
09-14-2017, 08:51 AM | #10 |
Rep 2,073
Bimmercode is rated highly. It can apparently activate VIM at any speed on the G30, which can not be done in E-Sys at the moment. That alone is worth the £30 for the app because people are charging around £100 to code VIM.
09-14-2017, 09:31 AM | #11 |
Rep 8,364
Bimmercode and Carly are rather limited as far as G-series at the moment.
09-14-2017, 09:35 AM | #12 | |
Rep 2,073
All I keep seeing on forums is what CAN'T be done with e-sys on the G30 right now (most notably VIM at any speed). If Bimmercode can do that as well as the other things that the casual coder can do with e-sys, isn't Bimmercode the better option? |
09-14-2017, 09:37 AM | #13 | |
Rep 8,364
09-14-2017, 09:38 AM | #14 |
Rep 2,073
VIM at any speed? I read a post by you that said only solution is a commercial solution currently.
09-14-2017, 09:40 AM | #15 | |
Rep 8,364
Bimmercode + Bimmerlink + Adapter = $85, but will work on multiple cars for VIM. Other solutions are specific to headunit so you must buy each time. |
09-14-2017, 09:43 AM | #16 | |
Rep 2,073
I do have e-sys already as I use it on my F10 but I will have to get Bimmercode for VIM when my G30 arrives. For anyone with a G30 and currently not having e-sys, they should consider Bimmercode if VIM is important to them. |
08-16-2018, 05:56 PM | #17 | |
Rep 25
Thanks |
08-16-2018, 09:38 PM | #18 | |
Rep 8,364
EDIT: Guess it was fixed and working again. Last edited by Almaretto; 08-26-2018 at 12:32 PM.. |
Shepway10.50 |
08-19-2018, 10:43 PM | #19 |
Rep 28
08-19-2018, 11:52 PM | #20 |
Rep 8,364
08-20-2018, 09:45 AM | #22 |
Rep 8,364
