09-11-2017, 10:19 PM | #1 |
Rep 297
Jl Audio Subwoofer With Everything U Need.....
Hello folk, I have here a JL subwoofer and AMP ready to install today. This kit comes with everything you need to install to your HK system, if you dont have Harman Kardon system the hardware will still work. There is no cutting thanks to a T adapter to the factory Amp. Once it goes to LC2i audio control base filter then to the momoblock JL 600/1 AMP this puppy sound good specialy coming from 2017 10w6v3 sub. With all the wires and bracket you will be ready to go. My lease is coming up in a few months Im slowly parting out my parts. This kit came from Musicar northwest in Portland they are usually on forms thats how I found out about this kit. $400 JL Audio 10W6V3-D4 10" 1200W Dual 4 Ohm W6 Series Car Subwoofer Power Handling: Peak: 1200 watts RMS: 200 - 600 watts Mineral-filled polypropylene cone Nitrile-butylene rubber surround Elevated Frame Cooling DMA Optimized Motor structure Cast Aluminum basket Push terminals Terminal Jumper System Single stacked ferrite magnet Resonance Frequency (Fs): 30.12 Hz Top-mount depth: 4-5/8" Sensitivity: 82.7 dB Recommended Enclosure Type: Ported / Vented Sealed Optimum Sealed Box Volume: 0.628 cubic feet Optimum Ported Box Volume: 0.828 cubic feet Weight: 26 LBS JL AMP XD600/1- $280 Rated Continuous RMS Power @ 14.4 V 600x1 @ 2 ohms 500x1 @ 3 ohms 400x1 @ 4 ohms Rated Continuous RMS Power @ 12.5 V 500x1 @ 2 ohms 400x1 @ 3 ohms 300x1 @ 4 ohms Frequency Response 7 Hz - 500 Hz (+0, -1dB) THD+N at Rated Power <1% at 2 Ω per Ch. S/N Ratio, referred to highest rated power >87 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth) S/N Ratio, referred to 1 W >59 dB (A-weighted, 20 Hz - 20 kHz noise bandwidth) Input Voltage Range at RCA Inputs 200 mV - 8 V RMS Fuse Rating 50 A (AFS, AGU or MaxiFuse™) Freq. Response 12 Hz - 22 kHz (+0, -1dB) Damping Factor at 4 Ω >1000 / 50 Hz Damping Factor at 2 Ω >500 / 50 Hz Source Ch. Selection for PreOuts N/A Remote Level Control Optional (HD-RLC) Filter Slope (dB/Octave) 12dB or 24dB Filter Modes Low-Pass only Filter Freq. Range 50-500 Hz Infrasonic Filter 30 Hz, defeatable Width 8.52 in / 216 mm Height 2.05 in / 52 mm Depth 7.09 in / 180 mm PENDING-SALE Car Audio 2-Channel Line Output Converter (LC2i) Model: LC2i 12 Volt trigger output GTO - Signal sensing inputs Dual amplifier, 9.5 Volt pre-amp outs AccuBASS processing for correction of bass roll-off Fixed and variable outputs with discrete level controls Dimensions: 6-3/8"W x 3-1/8"D x 1-1/2"H OE-Look Subwoofer enclosure- $280 The Musicar OE-Look for the F32/F82 platform is very similar to the F30/F80 sedan design. Replacing the battery access door, its lines flow into the design of the trunk. It’s easily removable in case access is required. It can accept a wide range of subwoofers, and its impact on the load-floor area is almost nil. PENDING-SALE harnesses and interconnection systems are engineered to be 100% PnP and electrically matched to OEM systems. No OEM wires cut, spliced or tapped required. 100% reversible back to OEM. No OEM errors or induced defects to your OEM system. https://photos.app.goo.gl/7ZdQECgyzkkJkMog2 https://photos.app.goo.gl/nDOxnnKrXqXgSfSG3 https://photos.app.goo.gl/FBfMdPM5cxmWPW4Y2 https://photos.app.goo.gl/PhC6txgqcIZ2uyQl2 https://photos.app.goo.gl/ivdx1LgMDFHPDuK52 https://photos.app.goo.gl/bglz4KKJJsfzQ8A22 https://photos.app.goo.gl/XnKx6rMidOorAZGB2 https://photos.app.goo.gl/89vpbxfBROkdEIun1 https://photos.app.goo.gl/Tqvr0hC8OAcxs8BI3 https://photos.app.goo.gl/7HMToFqSnslrazmE3 https://photos.app.goo.gl/JgvBRLadf7H5jgxJ2 https://photos.app.goo.gl/xBN8dSQeVsgLeUZH2 https://photos.app.goo.gl/ysI8c8p0CLtDHbHh2 Any question fill free to ask... Last edited by ronin_pdx; 09-21-2017 at 11:11 PM.. |
09-12-2017, 02:05 PM | #3 |
No 55mph
1623
Rep 8,479
None of your pics show up - Photobucket has had a new rule about 3rd Party Hosting for some time now - for anyone to be able to view the pics the way you posted them they would have to pay hundreds of $$ per year
So basically, no one is gonna see them... You need to go back & post them the long way using the 'Share' & Direct Link' method while in Insert Image forum icon - or use a different hosting site
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
09-12-2017, 04:42 PM | #6 |
No 55mph
1623
Rep 8,479
Yup
