3.5bar Adapter problem
09-15-2017, 07:29 PM | #1 |
Rep 50
I just got my DOC kit W/6466 installed recently. I just installed new plugs and coilpacks today. I have the newest JB4 single turbo firmware installed along with MHD BEF. I installed the BMS 3.5lb tmap adapter but the car is running rough and showing the half engine light. I'm throwing these codes 2ABC- Boost pressure sensor electic, 2ABD-Boost Pressure sensor overrun, and 3100- Boost pressure control, deactivation. However, when running the stock sensor everything work fine. I also changed the tmap setting in JB4 to 1. Do I need to get N20 Map sensor as well (BMW part 13627843531) for to work correctly. Any help is appreciated!
Thanks |
09-17-2017, 04:59 PM | #5 |
Rep 50
I'm running the stock sensor now because the 3.5 bar one I ordered doesn't work. However, looking closely I believe BMS sent me a 4LB bar adapte instead. It doesn't say 3.5 anywhere on it. What do you guys think?
09-17-2017, 10:01 PM | #6 |
Rep 779
N20 TMAP will have 3.5 stamped on it, doubtful the adapter harness does. People seem to have more trouble with 4 bar sensors than they're worth. Unless you need to be able to read >40psi, not sure what the purpose is for running them. If 36psi will work instead, just order an *OE* N20 3.5bar that works without question.
Edit: missed that you have a 3.5bar. Not sure on the adapter harness, but AFAIK, all it does is re-pin the wire locations, which you can do yourself if inclined. I have seen some complain of issues with generic N20 3.5bar TMAP replacements though. Is yours is OE or some Amazon/Alibaba equivalent? Last edited by RSL; 09-17-2017 at 10:07 PM.. |
09-18-2017, 06:21 AM | #7 |
Joint Chiefs of Staff
4927
Rep 116,037
09-23-2017, 08:36 PM | #9 |
MT or bust!
170
Rep 289
Drives: 2010 E90 335i M Sport, 6MT
i've gone through 2 adapters from BMS and 2 sensors from ECS. still can't get it to run correctly on my car as well. using MHD with the option checked. i get the same codes.
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
09-23-2017, 11:04 PM | #10 | |
Rep 779
If you're using JB4, set N20/3.5 bar option in JB4 and DO NOT select the N20/3.5 bar option in MHD. If you've selected the option in both MHD and JB4, that's your problem. JB4 is applying it's own 3.5 bar scaling on top of it already being converted in the flash. The N20 MAP option has to be set in the JB4 (i.e. can't select N20 map in MHD and leave JB4 set to stock 2.5 bar MAP), so leave JB4 set to 1 and reflash with the N20 option deselected in MHD. |
terryd5150507.00 |
10-03-2017, 10:38 AM | #12 | |
Rep 1,340
10-25-2019, 06:24 PM | #14 |
Rep 1,340
