E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Help with wastegate rattle
Reply
      09-16-2017, 09:10 PM   #1
painoz
Drives: 2007 335i, 2013 M5
Since installing MHD, I have a terrible waste gate rattle. The rattle is heard worse under the car and in the car, more so than in the engine bay. I tried the rear actuator adjustment, but it did not help. If I disconnect the vacuum cannister that is on the right as you stand at the front of the car, the actuator arm moves and the rattle is completely gone.
I am wondering if I did the actuator adjustment correctly. I loosened the 10mm hex nut. I turned the actuator arm clockwise (from the top of the engine) two full revolutions. If this is the correct procedure, any suggestions on what else to do?
Thanks,
Nate
      09-16-2017, 10:18 PM   #2
!LEFTCOAST!
!LEFTCOAST!'s Avatar
Drives: E92-SG-335i
I think you're supposed to turn the rod counter clockwise. If I remember correctly standing in front/top of the engine bay you turn the 10mm nut clockwise towards engine to loosen and the rod counter towards fender to tighten. There's a thread floating around with more info and pictures with directions on which way to turn the rod. GL!
      09-17-2017, 09:38 AM   #3
painoz
What you explained is turning the lock nut counter clockwise (towards the engine) and the actuator rod clock wise (towards the fender).
      09-17-2017, 05:32 PM   #4
!LEFTCOAST!
Drives: E92-SG-335i
Alright, guess I mixed up the two. The thread already made about this will have all the info for you.
Reply
e90post
