Idles Terribly When Cold
09-18-2017, 10:55 AM | #1 |
Stand-up Philosopher
75
Rep 184
For the past two weeks my '10 335i has idled terribly first thing in the morning when it's cold. It sounds like it's missing and shakes rather badly. As soon as I give it any amount of gas, it runs perfectly.
It idles perfectly when it's hot. Thoughts? Update in post 6. Resolved in post 12. Last edited by MooreBoost; 11-07-2017 at 02:33 PM.. |
09-18-2017, 11:01 AM | #2 |
3442
Rep 79,211
Does it smell like fuel at start up?
First thing I'd do is pull the plugs and see if they are fouled with fuel or oil. Fuel would be an indication of bad injectors, oil would likely be valve cover gasket. If they are fine and the plugs are in good shape at the correct gap then I'd start to look elsewhere. |
09-18-2017, 11:27 AM | #3 |
ahat
1046
Rep 2,592
I had two probs that had almost the same EXACT symptoms. At 100K, began to get rough cold starts with raw fuel smell. Would clear up after 30secs. Replaced injectors and solved prob.
Within 2 months prob somewhat returned but slightly 'better'... not as consistent. Ended up being FP number 4. But it did throw high pressure fault codes I think..
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
09-18-2017, 11:29 AM | #4 | |
3442
Rep 79,211
09-18-2017, 05:26 PM | #6 |
75
Rep 184
Pulled the following codes-
Active Codes 29F2 - Fuel high-pressure system, fuel pressure 2B2C - Fuel high-pressure, plausibility, cold start (Plus misfires) Shadow Codes 2FCA 2FDA 2FDB Is this further evidence of HPFP failure? Thanks. |
335e92tx1046.00 |
09-18-2017, 05:35 PM | #7 | |
ahat
1046
Rep 2,592
I think your there bud http://www.bimmerfest.com/forums/sho...92&postcount=3 2FCA and 2FDA are also shadow codes that show up after any software code update and have to do with hpfp not priming correctly, but most people get those codes even on brand new pumps and they rarely cause any issues.
JC_AD335i27.50 |
09-19-2017, 07:17 AM | #8 |
75
Rep 184
Taking the car to do the dealer on Thursday in hopes that it's the HPFP and that they cover it under the extended warranty.
Should I load my stock tune or keep the MHD on there? Specifically, I don't want MHD on there for obvious reasons, but I also don't want to clear the codes so that the dealer is able to see them. |
09-19-2017, 07:40 AM | #9 | |
ahat
1046
Rep 2,592
g/l
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 Last edited by 335e92tx; 09-19-2017 at 07:53 AM.. |
09-21-2017, 11:48 AM | #10 |
75
Rep 184
Well, will the codes didn't come back before my appointment today, after reloading the stock tune.
The service rep mentioned the HPFP after I described the symptoms, and said they would warranty it if the codes came back. So that's good news. Just have to wait now. |
09-21-2017, 12:22 PM | #11 |
ahat
1046
Rep 2,592
good deal -
05-16-2022, 07:43 PM | #13 |
Rep 211
I know this is a very old thread but Its exactly what I had going on on my 2010 E90 335. I suspected the HPFP but after reading this I was convinced that was it. I scored a NIB OEM HPFP from another member here for $400 and did it myself. All good now. THANK YOU
2019 F150 S Crew 4x4 3.5 Twin Turbo - newest $$$ pit
2010 E90 SG 335i Sport, Premium, Nav. MHD, VRSF CP, 5" HD FMIC, DCI's, 1 step colder NGK's, Apex EC-7's and Michelin PS4S, Cree 6000k H8 LED Angel eyes SOLD 2011 Toyota Tacoma DC TRDOR 4x4 lifted and armored SOLD 2014 Acura MDX SHAWD wifes |
Jaronbwall284.50 |
05-16-2022, 08:37 PM | #14 |
Rep 3,219
