09-21-2017, 11:26 AM | #1 |
Rep 281
Which vehicle for autocross?
My wife and I went to the Ultimate Driving Event hosted by BMW and as it turns out, she has a knack for A/X. Out of our group of over 20 guys, she was the second fastest by a large margin (fastest was an A/X veteran). Even the instructor, who is an M School instructor in Spartanburg told me that she has tons of talent and needs to get seat time. The good news is, she loves it as well.
Here is the problem: We own an old '87 3/4 ton truck, a GTI with a manual, her X3, and my 991. She can't drive the manual, trust me, we tried. The truck clearly won't work and I think it is a bad idea to use the 991 for a beginner especially since she isn't shy about eating a cone or two to hug the line. We looked into getting her a car (which I could also use for DE to start out with) and decided on either a 135i or older Cayman. However, neither one of those cars fit our budget for this little hobby that might fizzle away and we already have 4 vehicles with only a 2 car garage (also no space for a detached garage, I already tried). That leaves us with using the X3. BMW CCA will allow it to be used at their events but not SCCA due to roll over risk. It seems like many have done well using SUVs but I certainly don't want to risk a roll over. Does anybody have any experience or wisdom to share on this topic? Thanks!
09-21-2017, 11:37 AM | #3 |
Rep 3,050
Drives: 2020 M4 ZCP / 2023 X3 M40i
Get a cheap Miata although I'm not sure how good an auto Miata would be. You can also sell the manual GTI and get one with DSG.
09-21-2017, 01:08 PM | #5 |
Rep 525
It's great that you guys are wanting to do more fun things with your cars.
I would say just stick with autocrossing the X3 in clubs that are less strict on the roll-over policies. There should be multiple clubs/ogranizations in your area, other than just BMW or SCCA (PCA, for example). In case you quickly lose interest, and for your first year, I strongly recommend you just race what you have rather than modding or getting a dedicated car for it. You'll learn just as much for less money and less risk. Once you get a lot more seat time and better feel for the sport, you will start seeing what cars are good for all-around track/ax duty and what kind of mods are needed to be competitive. Until you get to this point, I say just save your money on just seat time and tires. Unless you have loads of money and/or like to re-do things, take my advice. |
09-21-2017, 01:42 PM | #6 | |
Rep 281
Thanks for the suggestions. The X3 is a 2016 (and her baby) and the GTI is a 2017 with 2.5k miles so we aren't interested in getting rid of them just yet.
The older miatas with an automatic are pretty terrible the last time I drove one. Base on what I read, the auto FRS is painfully slow, 0-60 in 8 seconds so I ruled that one out. Plus, FRS cost is in 135i territory and the 135i is fantastic. Quote:
09-21-2017, 02:58 PM | #7 | |
Rep 546
To prevent rollovers you can reduce the vehicle's height by adding lowering springs, and increase track width with lower offset wheels. Tire grip is important because if grip is low enough, you will slide before you roll, but if you put really sticky tires on it will be more likely to roll before sliding
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
09-21-2017, 03:01 PM | #8 | |
Rep 1,502
FBO M235i r
F80 M3 |
09-21-2017, 03:46 PM | #9 |
Rep 6,196
Agreed. The 1er will be faster in a straight line, but that's about it. AutoX is more about handling than acceleration.
09-21-2017, 07:43 PM | #11 |
European Editor
10871
Rep 22,992
Obviously the fastest car for auto crossing would be a RENTAL car!!
No... seriously... at this point you don't know if she will want to do A/Xing a lot or just a few times. Why not rent a car ? Or rent a seat in someone's prep'd racer A/Xer car. Dack
09-21-2017, 07:49 PM | #12 |
Rep 5,528
You can drive about anything at autocross. Why not do it a few times and see if she enjoys it? If you want to get more serious, get a different car.
Although it'll be hard to compare lap times with anything while driving an X3. Most likely it'll be the only X3 there with few similar competitors.
Auto Detailing Enthusiast!
Dackelone10871.00 |
09-22-2017, 11:06 AM | #13 | ||
Rep 525
Miatas are good cars if you plan on only doing autocross. Even if you only plan on ax, there are plenty of time trials, club trials, hpde, and open track days that will eventually tempt you. When that happens, Miatas won't be as fun as some other cars (at least, I wouldn't think so) since they're so slow outside of ax without heavy modification. FRS/BRZs are like slow S2000s, lol. They're great at handling but aren't that fast straight line. Similar to Miatas, they're much more suited to ax, but less so for bigger tracks. edit - Just noticed you're in E TX. Where are you located? I'm in Dallas. We have weekly events (ax, time trials, club trials, hpde, open track days, drifting, etc), just FYI. I've been doing this for quite a while and sometimes instruct at these events, so let me know if you ever feel like venturing out this way! Quote:
OP, I'd say keep it stock in the beginning but since your concern is roll-over, there are some simple things you can do to reduce this risk: -lowering springs to lower center of gravity -wider track with more aggressive wheel offset -minimizing body roll with sway bars -alignment with bit more negative camber |
Dackelone10871.00 |
09-22-2017, 11:49 AM | #14 | |
Rep 281
Thanks for all of the great feedback. I think we have a clear(er) pathway moving forward.. In the original post, I left out one piece of information, we also have a '99 Boxster. I didn't mention it because we were supposed to sell it. But after seeing the responses on here and rennlist, we are going to keep the Boxster and spend some money to get it mechanically sound. We took it out and she actually finds it easier to drive than the GTI, less rev hang so easier to time the the clutch. We were able to get the Boxster for under $5k and it will cost another $4k to get all of the known failure points in the engine addressed. This works out great because I didn't want to sell it in the first place. The only problem now is that BMW CCA won't allow convertibles without a full roll cage. Is this true on A/X or is it only for HPDEs? We are going to use the X3 for the first few events so she can get more comfortable with the manual.
We are just west of Longview and actually go to Dallas frequently. THe plan is actually to be there tomorrow to drop off the Boxster at RAC performance. Please shoot me a PM, I would love to learn more about the weekly events! Since our schedules are all over the place, it is a bit difficult to find events that fit in so if you have weekly events, we would love to learn more.
Dackelone10871.00 |
09-22-2017, 12:12 PM | #15 |
Rep 525
For AX, lack of roll cage shouldn't matter, unless it's like that one convertible SUV from Nissan or something -- even then, some local clubs will still probably allow it. For track, this is heavily local chapter/club dependent, so you'll have to contact your chair or point of contact.
No need to change anything on the X3, really. Most don't go fast or aggressive enough to cause even a hint of roll-over as-is. It's actually harder to roll-over vehicles than you'd think, but that it can happen under right conditions is why you just need to be careful. Also, don't worry about tires, it won't make much difference. Another thing to keep in mind is the type of surface and lot you autocross on. If there are pot holes, curbs, or grass, you need to be aware of how you approach elements around those. Hitting those at the wrong angle (ex. laterally) could cause a roll-over, but course designers are supposed to take all that into consideration so not really your concern unless you're just all over the place (in which case, you'd get an instructor). I actually work like 10 min from RAC, lol. I'll PM you, but just for those who are curious, check out the below link for all AX events in the Dallas Fort Worth area: www.dfwautocross.com |
09-22-2017, 06:07 PM | #16 |
Rep 601
Have you thought about an Audi A3 or A4? When I lived in Reno NV ... the AX folks were all about them. One kept trying to buy my A3 2.0t. The 6spd auto transmission is pretty darn impressive too. You can pick one up fairly reasonably.
09-23-2017, 04:06 PM | #19 |
Rep 5,795
Drives: Beige G31 540ix m sport
How about a e36 328i or a e46 330i? Both are inexpensive to buy & it wouldn't matter to much if it got damaged
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
09-24-2017, 03:35 AM | #21 |
2JZ-GTE
3188
Rep 4,174
S2000
09-25-2017, 11:50 AM | #22 |
Hoonigan
6942
Rep 3,017
Drives: '09 328i, '98 Wrangler
I second this. Not much money lost if she decides it isn't for her down the road.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
Chappers 716082.50 |
