Car stuttering in 6th at 2K after new plugs
09-22-2017, 05:54 PM | #1 |
Rep 592
2007 335i
MHD stage 1 97k miles auto Last week, I changed my spark plugs and the cylinder 6 coil to fix a cylinder 6 misfire (plugs already had 10k, so I changed them all since I was already in there). Since then, I've had some stuttering in 6th gear when accelerating moderately from 2k RPM. I can reproduce this consistently, and after doing so about 20 times, I still have not gotten a CEL or a code in the scanner. I tried autologging and didn't see anything funny, but I'm not an expert at reading MHD logs. Do my logs show anything? Are there other parameters I should be logging? The car seems to run fine outside of this situation (also happens in 5th at 2k, but less often). https://drive.google.com/open?id=0Bz...G5RcDBiRmNNWjg |
09-22-2017, 06:33 PM | #2 |
ahat
1046
Rep 2,592
Reset all adapts first (prob not throttle) and then do a manual of steady state speed (static throttle position) with at least 10 seconds of data . AND upload to datazap.me
Will try to have a look. No real definitives... Usually related to load req exceeding load actual at around 10-12 percent throttle based on what I have seen. Why is unclear.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 Last edited by 335e92tx; 09-22-2017 at 07:30 PM.. |
09-23-2017, 11:43 PM | #4 |
Rep 1,484
are you using the same brand coils for cylinder 6 as the rest of your cylinders? Germany cars are picky and don't like it when you mix and match brands.
You try swapping out coil in cylinder 6 with a different one? You check the spark plug in cylinder 6, make sure nothing is damaged or chipped? |
09-24-2017, 05:05 PM | #5 |
Rep 1
Your logs look fine.
I was having this same issue on the stock tune and it turned out being carbon build up. These motors are so dang touchy and mine were horrid. I just bought my car 15k ago and its at 95k, I'm almost positive it's never been cleaned. After cleaning manually with a gun cleaning kit and lots of brake cleaner, I reset the adaptations and took it for a drive. It was still missing for around the first hour of cruising around, then it just stopped. Car is running beautifully on MHD Stage 1 FMIC. Id recommend doing what Temjin said, if none of that fixes it, It's possibly an injector, but I would try cleaning for carbon build up, especially if you've never done it. It's recommended around every 30k on regular pump gas. They get BAD quick. |
09-25-2017, 10:53 AM | #6 | |
Rep 592
09-25-2017, 10:57 AM | #7 |
Rep 592
09-25-2017, 11:06 AM | #8 | |
Rep 592
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I didn't bother switching them around, I just replaced it with a new one. To me, it wasn't worth the time to mess around with it when the original part has almost 100k on it and the replacement part is cheap. The old plug looked fine but I replaced it anyway. I had a CEL for cylinder 6 before replacing it and the coil, but with the new stutters, I'm not getting a CEL, and they're happening at a different time from before. |
09-25-2017, 11:08 AM | #9 |
Rep 592
I had a walnut blasting done about 35k miles ago.
10-16-2017, 04:19 PM | #10 |
Rep 176
I think I have a similar, or even the same problem as you. Check out my thread on it. Did you happen to figure out what was wrong? Interestingly enough I have the same Amazon coils as you and after looking into it, they might be the culprit due to counterfeit/poor amazon quality. I'm about to order some Eldor coils and I'll reply back if those change anything.
10-16-2017, 05:00 PM | #11 |
Rep 2,189
10-17-2017, 05:26 PM | #12 | |
Rep 592
